The term "Fuse Block (J/B) always refers to the fuse block in the cabin/driver side footwell area (J/B= Junction Box). The following diagram from the FSM shows the location and fuse #. I indicated #10 for you:
The above is from the 2010 'vert. I doubt there is any difference between 2010 and your 2011, but check your copy just to be sure.
Hope this helps...
