Blown Fuse?
Old May 21, 2011 | 11:42 AM
Cdng37's Avatar
Cdng37
Blown Fuse?
I changed the vanity bulb in my G37S but it seems to have blown a fuse and now the memory seat does not work also? Does any one know what fuse to check under the driver side fuse panel? or is there something else to check? Help!!!!!!!!!!!!!!!!!!!!!!!
Old May 21, 2011 | 01:45 PM
Cdng37's Avatar
Cdng37
Any suggestions guys? I can't move my seat in order for me to drive the car Pls Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 22, 2011 | 03:19 PM
silverg37's Avatar
silverg37
change the fuse, bascially get the pen which checks which fuse is working and if it isnt then replace it
Old May 22, 2011 | 04:35 PM
G37SBS's Avatar
G37SBS
There is a fuse box at the left side under the hood release and the clutch.
so open the box and there is the map at the back of the cover.. what you need to do is remove the 10A (ROOM LAMP 4th one from the bottom left) using "Fuse Puller" (Top Right) That's the bad fuse. Now remove the 10A (SPARE 2nd one from the bottom left) and replace it.
let me know how it goes. good luck
Old Nov 12, 2018 | 01:04 PM
ETBszn's Avatar
ETBszn
Help with fuses
I’m having a similar problem. I was changing the vanity light while the car was on and when I did my steering wheel tilt stop working and my dome lights won’t come on, also my auto up on all 4 windows stopped working. Driver seat stopped operating as well. I have a 2009 Infiniti g37x sedan, if anyone can help me I’d appreciate it
Old Nov 12, 2018 | 01:35 PM
Baadnewsburr's Avatar
Baadnewsburr
try changing the fuse as described above.
the auto up just need to be reprogrammed by you. roll the windows more than halfway down and roll them back up all the way. when they get to the top (Closed) don't let off of the switch (keep for 3 seconds extra. programming done. there are proper instructions on this site in a sticky if you look for a minute or two you will find it.
Old Nov 12, 2018 | 03:02 PM
ETBszn's Avatar
ETBszn
It didn’t work when I did
Amaadkhan2k
Oct 4, 2024 01:20 PM
cshawsg37
Sep 25, 2015 05:33 PM
CiViCKiDD
Sep 24, 2015 10:47 AM
dsolis
Sep 17, 2015 11:25 PM
chris_s
Sep 8, 2015 03:37 PM
