Top up or down with a single press
Just finished installing the one touch module and nav bypass. Very simple and straight forward to install.
When installing both modules together...
Switch 12V connect to purple (main harness behind radio brain)
Ground connect to black (main harness behind radio brain)
Blue and Black of Relay connect to grey VSS (main harness behind radio brain, first grey wire from right on top row when look at the pins of connector)(there is 2 grey wires side by side)
Purple connects to Orange (main harness behind radio brain)(only if you have a backup camera)
Rest of connects are straight forward from the instructions that you get with the module.
And dont forget when you hook the battery back up that you have to do the window learn and roof learn otherwise both will not function properly.
Install is very easy. Access to the back of the switch for the top should be a lot easier in the automatic because there is a little more room between the shift mechanism and the switch & the center console is a separate unit.
Access to the switch with the manual trans requires removal of the center console which isn't hard but requires a few extra screws to be removed.
Fail!! what with World Cup and Formula1 this weekend, I got zero done that I was planning on doing...
Without any schematics... I assume this module is just supposed to be placed in parallel with the top open and close switches?
I know this thread is for the top up/down one touch module but i have question about the nav bypass.
Will i be able to watch videos from the AUX input while driving? For example, connecting a dvd player or ipod via AV cables (AUX) and watch videos while driving.
For legal and liability reasons we neither support nor condone modifications to the installation of the NI35 to allow video while moving. If such modifications are made they are 100% up to the discretion of the owner of the vehicle and the installer.
Finish the install yet? How did it go? Did you document it (especially trim removal)? I am interested as I just ordered mine today.
I like it and would be interested in getting it. I just installed their Nav Bypass & it is awesome!
I have previously contacted KPTech and requested better access to the Music Box functionality too - preferrably via USB.
-Barry
PS - Did you know that you can hold down the black rubber door lock/unlock thingy on the outside of the door by the handle and it will unroll the windows & eventually the top?
-Barry
Peter
To do a roof learn you just need to run the roof thru the complete operation of open and close like you do to relearn the windows open and close.
If you hook the battery back up and get a beeping sound from behind the drivers seat you need to open and close the roof and it will stop.
I learned the hard back in the winter i had the battery disconnected and then reconnected it and could not figure out what the beeping was all about. After a couple of days of think about it i opened the roof and close it and the beeping stopped.
