Interest in shock sensor add-on to factory alarm?
Old Mar 14, 2006 | 04:37 PM
  #166
Gilley's Avatar
Gilley
Florida G35 Club, General Member
I want mine connected to the trunk pin.
Old Mar 14, 2006 | 04:39 PM
  #167
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
dave
i would also leave the black wire alone and just move it to a different input.
i am in missouri visiting my parents so i dont have my 350z service manual, but i am flying back into tampa tomorrow so i can look into it better tomorrow night and report back with what i find might be the best fix.
  #168
SFLG35's Avatar
SFLG35
yeh yeh yeh
thats what i use now
the bc garage works off a trial and error basis
which is not to say that i made an error in my previous installs (they all work correctly and will work), we just have found a better solution.
Old Mar 14, 2006 | 04:41 PM
  #169
Gilley's Avatar
Gilley
When is the BC garage going to be back in Orlando?
But wait, I'll be in Tampa/Clearwater this Saturday.
Old Mar 14, 2006 | 04:53 PM
  #170
dabomb's Avatar
dabomb
Yes Dan, mine is working fine....except that occasionally i hit lock twice and only the sunroof closes or only the window but 85% of the time both close
Old Mar 14, 2006 | 05:56 PM
  #171
SFLG35's Avatar
SFLG35
you might be hitting it too fast for the window
try and sow down your pulses a little bit and that shoudl take care of that
Old Mar 14, 2006 | 06:49 PM
  #172
dabomb's Avatar
dabomb
but one of them closes and the other doesnt.....how could it be the timing?
Old Mar 14, 2006 | 08:55 PM
  #173
DavesZ#3's Avatar
DavesZ#3
Thanks guys for all the replies, questions and suggestions... let me see if I can cover them all....
I'm using the truck/hatch pin for the trigger. I saw the warnings about the door pins drawing too much current so I went with the trunk pin.
Dan, you wrote "leave the black wire alone and just move it to a different input". What "it" are you referring to, the trigger? Or, the sensor itself? Is the steering column the recommended place now? Or, should I just try to get it farther away from the door (kick panel)?
Does it matter which orientation the sensor is mounted in?
I believe Dan's explanation about the door closing causing the sensor to ground the trigger and make the BCM think that the door/hatch is open is right on target. Since the black wire controls when the sensor "turns on", that's why I thought if it went on a delayed power, it would stay off for a few seconds more allowing me to close the door and have it not trip the trigger.
Dave
Old Mar 14, 2006 | 10:09 PM
  #174
SFLG35's Avatar
SFLG35
what i meant by that dave was maybe move teh trigger wire off the door pin to the trunk pin but it appears that you already have it on the trunk pin. you could try moving it to a different location that might help
no that doesnt matter
you can mount it however you want.
i think that would probably be the best thing dave but i am not sure where you would find that type of wire.
ill talk with kevin and see what we can come up with. like i said before i dont have my service manual with me since im at my parents.
Old Mar 14, 2006 | 11:53 PM
  #175
mdemonte's Avatar
mdemonte
When do I get mine installed?
Old Mar 15, 2006 | 10:13 AM
  #176
SFLG35's Avatar
SFLG35
whenever you come to my apartment.
if yu want to come by on thursday just give me a call.
the only thing i have planned now that jason isnt coming is goin to the track at 5
Old Mar 15, 2006 | 03:11 PM
  #177
mdemonte's Avatar
mdemonte
Oh who picking u up from the airport? My neighbor?
Old Mar 15, 2006 | 08:52 PM
  #178
SFLG35's Avatar
SFLG35
no
shes in cali
ryan actually picked me up
Old Mar 15, 2006 | 08:57 PM
  #179
Chucky
Guest
Posts: n/a
no
shes in cali
What a nice guy... and hair.
Old Mar 15, 2006 | 10:04 PM
  #180
SFLG35's Avatar
SFLG35
that he is
thanks again ryan
hit me up tomorrow when your on your way over
