wheel weight
Old Sep 14, 2006 | 05:02 PM
Gilley's Avatar
Gilley
Florida G35 Club, General Member
The new numbers of 8.5 245/40 and 9.5 275/40 is more conservative, but should work well if the offsets are right.
Old Sep 14, 2006 | 09:55 PM
r10apple's Avatar
r10apple
Man, I am all over the map on this...
I keep seeing TONS of guys with 10" and 10.5" wheels. Have you guys all done anything truly special for that type of fittament? I mean, if I am even going down to an 18" wheel, the diameter is actually going to be shorter, though clearly, this will be a wider set up. I know RUBBING is the main issue, but do you guys truly have this problem???
Secondly, not only am I looking for wider, I'd love to have a wider lip on the wheel, though, I do not want 30lb wheels, either. I am trying to stay under $500 a wheel, and I really do not want to get Volks regardless of how good they may be...Any thoughts/ideas from anyone???
If I stay with the 18x9.5's, I may just go with 5Zigen FN01R-C's in black...
Old Sep 14, 2006 | 10:09 PM
r10apple's Avatar
r10apple
Here's the Axis and the 5Zigen wheel...
Old Sep 15, 2006 | 08:14 AM
Gilley's Avatar
Gilley
I have 20x10.5 and a 285/30 on the rear and I don't rub on 350Z S-Techs.
Old Sep 15, 2006 | 08:37 AM
2FastG354U's Avatar
2FastG354U
What do stock 18 inch rims weigh?
Old Sep 15, 2006 | 09:10 AM
r10apple's Avatar
r10apple
That's great news, Gilley: what's your rear offset???
Old Sep 15, 2006 | 09:30 AM
r10apple's Avatar
r10apple
Hey--what width wheel, and what tire size are you running up front as well? Offset for that, too???
I'd still like to track the car every now and then at some point and going to 18's--even after talking to Axis--even though they are wide should still cause no rubbing with the right offset, right?
I feel like I am sooooooooo overthinking this, but I want functional wheels that do look good, any my tastes are a little different than most...
Old Sep 15, 2006 | 09:36 AM
Gilley's Avatar
Gilley
I'm running Maya GR5's 20x9 +26 offset front and 20x10.5 +29 offset rear. The tires are BFG KDW2's 255/30/20 front and 285/30/20 rear.
Old Sep 15, 2006 | 10:59 AM
r10apple's Avatar
r10apple
I really appreciate that. I may just go ahead and order the Axis' and see if they are gonna work out...
Old Sep 15, 2006 | 11:00 AM
_jb's Avatar
_jb
Not at all... there's a lot to think about when squeezing a set on wide tires on a G35.
Check out this tire/size/offset web page. It's about the best I've seen for figuring out tire sizes and offsets.
Old Sep 15, 2006 | 11:33 AM
r10apple's Avatar
r10apple
Well, what's the offset of the stock wheels??? Anyone know that (I am searching as well speak)?
Old Sep 15, 2006 | 11:38 AM
Gilley's Avatar
Gilley
I'm thinking 30 front and 33 rear since they are 8 inches wide in front and 8.5 in the rear.
Old Sep 15, 2006 | 12:45 PM
r10apple's Avatar
r10apple
Thanks for the offsets Gilley. This also really helps, _jb...I'm headed over to my shop now...
Old Sep 15, 2006 | 04:52 PM
  #29
CleanGThree5's Avatar
CleanGThree5
Hey I have 19x9 and 19x11 HRE's, these are only 27-30lb each and so they have good width, little weight and didnt have to modify anything, no rubbing at all.
Old Sep 15, 2006 | 05:07 PM
  #30
_jb's Avatar
_jb
Correct as always, Sean.
