Loose Fan belt
Old Jun 28, 2006 | 06:19 PM
WILD121's Avatar
WILD121
Florida G35 Club, General Member
Loose Belts
Anyone know how to change out the fan belt. I started up the car this morning and my baby started screetching like a Bitch. It finally stopped but im a little worried about it. This is the second or third time this has happened. Also does anyone know the negative effects on your engine if you drive witha loose fan belt for too long.
Thank in advance
Old Jun 28, 2006 | 06:36 PM
cj350's Avatar
cj350
Originally Posted by WILD121
this morning my baby started screetching
Maybe its hungry. Give it milk. How old is your baby??? jk
Drop a drop of oil on the inner belt and the sound should go. I am not sure if this is good but i am sure its a quick fix.....a few drops from the dip stick should do it........
Old Jun 28, 2006 | 07:12 PM
Gilley's Avatar
Gilley
If you don't get your fan belt fixed, it will break and your car will overheat and die.
Old Jun 28, 2006 | 07:38 PM
Audible Mayhem's Avatar
Audible Mayhem
Performance Factory
there isnt a fan belt, we have electric fans!!
now you have a AC belt and a power steering, water pump and alternator belt...
maybe its one of those, it might be your blinker fluid also..
its easy to change if you plan on doing it
Old Jun 28, 2006 | 07:43 PM
Chucky
Guest
Posts: n/a
I had a similar problem and it turned out to be a loose bolt in the brake fluid resonator. I would start there.
Old Jun 28, 2006 | 08:30 PM
Audible Mayhem
Performance Factory
those damn Nissan bolts!!
Old Jun 28, 2006 | 09:40 PM
WILD121's Avatar
WILD121
okay Im pretty sure its one of the belts happens only in the morning then when it warms up it runs just fine. I just dont want to take it in just for new belts.
hey Jermey could a Novice do it with a little instruction and some hand tools(excluding a torque rench). Im always worried about proper torque specs specialy whenit comes to pulleys. Dont anything flying off when I driving down the road.
Chuck, how the hell do I check that.
Oh and if anyone wants to help me do it Im sure it will be a fun time watching me screw up my car.
Old Jun 28, 2006 | 09:46 PM
WILD121's Avatar
WILD121
Oh I forgot Im probably going to need a Pulley tensioner. I think right. not sure. This sucks. RRRRRRRRRR. Maybe Ill just buy one.
Old Jun 28, 2006 | 09:52 PM
Chucky
Guest
Posts: n/a
Yes...
Old Jun 28, 2006 | 09:54 PM
WILD121's Avatar
WILD121
while Im at it I should just go ahead and get unorthidox Pulleys since Im doing all this.
Audible Mayhem
Performance Factory
pulley tensioners are for girls!!
all you have to do is remove that stupid plastic cover that covers up the whole bottom of the engine, look up there and you will see two belts, these two belts spin around the ribbed sections, one has 6 ribs, one has 4 ribs, these belts also spin around one pulley that has no grooves on it, this is the pulley that tightens up and keeps the belts tight. the way this tightens up is ..
these is a 14mm bolt in the front of the pulley. you have to loosen it first. then the only other step is to look up from the bottom, there is a 12mm bolt that makes that pulley go up and down,
basically loosen the 14mm then turn the 12mm from the bottom and it will give you slack in the belt. then remove the belt and put on the new ones
you will need to then tighten up the 12mm till the belt is nice and tight, then tighten the 14mm in the front and you are done.
both belts are exactly the same....
they are the smaller black pulleys on the side of the big one in the middle
good luck!!
Old Jun 28, 2006 | 09:55 PM
GLuXuRy's Avatar
GLuXuRy
LoVeS GEE Baby
i thought belt driven fans were like played out like years ago...most fans are electric now a days
Old Jun 28, 2006 | 10:01 PM
WILD121's Avatar
WILD121
Thanks Jermey. Ill give it a go after a little more readig. Doesnt seem that hard if its only two bolts.
Old Jun 29, 2006 | 01:37 AM
truplay8's Avatar
truplay8
no ****..........this screetching has been happening to me almost everyday for the last few months when i turn on my car.............keep us posted jason, i need to know what to tell the dealer when i go in
Old Jun 29, 2006 | 08:23 AM
dabomb's Avatar
dabomb
FGC Central Florida BOD
whos jason?
