Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Review OBX Resonated Test Pipes
Old May 5, 2016 | 10:40 AM
MaQG37's Avatar
MaQG37
Originally Posted by jfisher
Brad, how did you apply the RTV when using the Z1 gaskets?
If you haven't installed your new TP's yet, I'd highly suggest grabbing Z1 metal gaskets. Use the directions from the RTV bottle, applying a thin layer on both sides, and waiting for the RTV to cure before re-torquing. My mechanic actually just use copper RTV spray on my metal gaskets and they don't leak. Well, they sound like they leak but it's just the nature of the beast when running test pipes.
Old May 5, 2016 | 10:51 AM
jfisher's Avatar
jfisher
I have the z1 gaskets ready to go. Hopefully get them installed this weekend. The gaskets that came with the TP's are already blown on both sides.
Old May 7, 2016 | 03:22 PM
LPV36's Avatar
LPV36
Update: 550 miles so far. No CEL. Here's a cold start video
Old May 7, 2016 | 04:47 PM
Just a thin film of the RTV on both sides of gasket, lightly snugged the bolts, waited an hour, then torqued it up. You're not supposed to drive it for 24 hrs. but I could only wait 12 lol. So far so good
Old Aug 12, 2016 | 08:59 AM
jfisher's Avatar
jfisher
My CEL seems to come and go. I saw it pop back up on my dash yesterday and hasn't gone away yet
Old Aug 17, 2016 | 07:01 AM
djdiskino's Avatar
djdiskino
How's the gas smell inside the cabin? With the AC or Heat on do you smell it? Really looking into high flow cats right now to pair with my stillen catback.
Old Aug 17, 2016 | 08:28 AM
djdiskino's Avatar
djdiskino
Is this with your blown gaskets? Or have you updated your gaskets to the Z1's now and your getting CEL's
Old Aug 17, 2016 | 09:21 AM
jfisher's Avatar
jfisher
I don't have any gas smell whatsoever inside the cabin. If you're outside of the car, behind the car, you can smell it if you try, but it's not nearly as bad as most people make it out to be. IMO at least.
This is with the new Z1 gaskets and RTV. CEL was still on as of last night when I got home.
Old Aug 17, 2016 | 12:42 PM
I've got a feeling one of your sensors is problematic, since you've had intermittent problems over time. No CELs on mine and another 1500 miles in the books, about 7k miles now.
And ditto what Jfish said about the smell, it can be strong in an area w/ no breeze and you wouldn't want to be behind your car w/ it running for very long, but you won't notice it when driving. If you're in a traffic jam or a drive-through waiting for food I'm sure the car behind you won't be that excited w/ your test pipes
Old Aug 17, 2016 | 05:47 PM
djdiskino's Avatar
djdiskino
Thanks for the responses guys. About to pull the trigger. I live in MA so not sure about passing inspection. My friend does my inspections and doesn't hook up anything other than and OBD so I think I should be fine. What are you guys doing about inspection?
Old Aug 17, 2016 | 07:16 PM
In New Mexico there's none, as long as your cars not on fire as you go down the road you'll be left alone
Old Aug 17, 2016 | 09:36 PM
djdiskino's Avatar
djdiskino
Lol! Just ordered my set can't wait! Need to order z1 gaskets too
Old Aug 18, 2016 | 06:34 PM
djdiskino's Avatar
djdiskino
Are these the gaskets you ordered @blnewt?
https://www.z1motorsports.com/exhaus...25-p-8909.html
Also do I only need 2 right?
Thanks in advance
Old Aug 18, 2016 | 08:54 PM
  #29
No, these are the ones (the upper gaskets that go to the headers) and you will need 2.
https://www.z1motorsports.com/exhaus...ts-p-6448.html
You can re-use the oem 2 bolt stacked thin metal gaskets, or the ones that come w/ the RTPs w/ a smear of high temp RTV on both sides.
Old Aug 19, 2016 | 04:48 PM
  #30
djdiskino's Avatar
djdiskino
Hmm for completeness I'll probably grab the z1's so I don't have to return to this job later to fix it. Thanks blnewt!
