Help Slow crank no start
Old Today | 03:29 PM
Setflyn41's Avatar
Setflyn41
Slow crank no start
I recently bought a 2008 g37 coupe was diagnosed by a shop to need a starter, when I got it it would crank one time then stop. I replaced the starter same symptoms, bench tested the new starter and it works fine, tested voltage when cranking drops from 12v to 8v. Already tried the battery out of my running car and produces the same symptoms
Started chasing grounds to clean them up and found water in both passenger and driver floorboards. Checked ECM BCM and IPDM all seem to be fine no signs of water intrusion
Replaced negative cable terminal to ensure tight connection
tested all fuses
ran the negative cable of some jumpers from the negative to the engine block and same symptoms
engine turns over by hand and I pulled the plugs to make sure it wasn’t hydrolocked
running out of ideas of what to try maybe someone has had this issue in the past?
Jays g37s
General Tech Questions
Dec 22, 2025 11:39 AM
chitty
May 6, 2025 09:04 PM
Bxrry
Jan 13, 2025 01:12 AM
Itsrm
Mar 31, 2023 06:17 PM
akeyes01
Jun 7, 2021 11:04 AM
