Car developed a ticking noise after changing gasket between cats and y pipe
Old Dec 14, 2021 | 07:46 PM
MStrike's Avatar
MStrike
Hi, my car had recently developed a ticking noise that is coming toward the front side of the engine. I have researched the forum and came across various possibilities, but have not been finding luck in narrowing it down. I know the heat shields rattling is a good option, but my noise is coming from the front of the car as opposed to near the Y-pipe. Additionally, some individuals have stated that the fuel damper could be failing, which I examined using a mechanic's stethoscope and found that much of the noise was coming from there. However, I replaced this part 2 days ago with a used one but the rattle is still there.
I think I might've heard a few people talking about the purge valve or camshaft while others stating the possibility of needing to use Nissan ester oil alongside a TSB, but I wanted to share my issue with you guys in case anyone had experienced a similar thing before. Additionally, here is a sample video of the noise, which mainly develops and increases in speed around 2-2.5k RPM. Thanks.
Old Dec 14, 2021 | 08:16 PM
Said Amir's Avatar
Said Amir
From the video, it sounds like a puffing noise, as if you have some sort of exhaust leak. Did you use the OEM metal gaskets? Also, did you inspect the flex pipes?
Old Dec 14, 2021 | 09:48 PM
MStrike's Avatar
MStrike
No, I didn't use the OEM gaskets (got some compatible MAHLE steel ones from AutoZone) as I had done this task while being under the car checking for exhaust leaks using soapy water. Additionally, the flex part of my y pipe is shot, but I have bought the upgraded Z1 gaskets while scouring options for a new pipe.
I want to ask though, if that noise was due to the exhaust leak, then why was the sound concentrating all the way in the front of the car? Would it have something to do with an additional exhaust leak being present in the headers as well? Thanks.
Old Dec 14, 2021 | 10:11 PM
Said Amir's Avatar
Said Amir
Might be your flex pipe then, because I can't really hear much of the ticking that you are mentioning. Well, do you have test pipes?
Old Dec 15, 2021 | 12:13 AM
MStrike's Avatar
MStrike
No, I have some aftermarket catalytic converters that the previous owner recently replaced at the time of purchase (1 year ago). Tomorrow, I will try to get a better clip of the ticking noise that I am mentioning.
710merlin
Aug 24, 2023 09:36 AM
Wonder2800
30
May 4, 2022 12:57 AM
dany_rizkallah
Jul 16, 2018 03:12 PM
who4ever
Oct 27, 2011 01:26 PM
TicketProof
Intake and Exhaust
May 22, 2009 04:15 PM
