Help Recent spark plugs and throttle cleaning
I changed my spark plugs and cleaned my throttle body. Now it’s sounding odd and I can’t figure out what wrongs with it. There’s no check engine light. Any ideas of what it could be or what to check?
Define "sounding odd"? How's it idling? A little more description of the problem will help us help you.
Here are the relearn procedures you HAVE to complete after a throttle body/MAF cleaning:
Here is a much easier way to complete the final Idle Air Volume Relearn :
here’s the link with a video
https://www.reddit.com/r/G37/comment...tm_name=iossmf
What plugs did you use and did you gap/check them yourself?
You also have a disconnected breather hose on the passenger side that goes to the intake tubing. I see you capped the PCV intake ports on the manifold and are venting the PCV valves to atmosphere.
Sounds like a misfire.
Alagator28
17
Jun 8, 2018 02:51 PM
slotterjordan
Jan 6, 2017 03:50 PM
MrRat
12
May 3, 2008 12:16 AM
