Help Rattle/ticking noise
I have a 2013 G37 Sedan I bought last month, has 130k miles on it. Only mods are an intake and cats have been removed/replaced with test pipes.
just a few days ago I noticed a rattle/ticking sound. Im a little clueless at this point as to what it could be. I checked the oil level and it was low. It had about 1/4" on the dipstick. I added nearly a quart to get the level right but this made no difference. The thing is, I only hear it when in drive. If I'm in park or neutral I have to rev it up pretty high to hear the noise.
Any ideas on what this could be?
Spoiler
Check all your fluids. (Change if necessanecessary)
Check for codes. (Address as necessary)
Do the throttle body clean and idle relearn.
Get yourself an oil gauge and make sure your oil gallery gasket ain't leaking interinternainternally.
if all else fails, turn up the radio
It could be something as simple as a loose heat shield or an exhaust leak, or something as catastrophic as beginning of an engine failure. We can't help you unless you help yourself by doing further diagnosis.
Haven't cleaned the TB and idle relearn.
If I'm not mistaken, half of 2012s and all of 13s have a newer gallery gasket that doesn't fail like the older models?
I'm leaning towards an exhaust leak based off of some research I've done. Considering I only hear it in drive and I just put the test pipes on a week ago, I feel like this is the likely culprit.. I'm going to check to make sure all bolts are still tight and then I'll try spraying soapy water and blowing air in the tailpipe.
I didn't know an exhaust leak could make such a scary and horrible sound.
Mohamed Naim
Oct 30, 2022 01:13 AM
Slayerg37
Jan 30, 2015 09:30 AM
