Had code P0340, replaced both camshaft position sensors but SES still there.
Old Sep 11, 2020 | 08:24 PM
MStrike's Avatar
MStrike
The Service Engine Soon light is still on and I can feel the misfires. Now, it's leading me to think that it has something to do with the wiring harness. Should I do anything else before taking it to a mechanic, and what should I estimate the repair cost to be?
Old Sep 12, 2020 | 12:24 PM
juster's Avatar
juster
Did you reset the computer then the codes came back?
Old Sep 12, 2020 | 01:33 PM
MStrike's Avatar
MStrike
Yeah, and I still feel the engine misfires
Old Sep 12, 2020 | 02:44 PM
juster's Avatar
juster
Can you see the voltage on your battery? Service manual says a weak battery could be a cause.
Old Sep 12, 2020 | 04:28 PM
MStrike's Avatar
MStrike
I had just tested it out, following this video
, and my battery was around 12 v to start and once it was running it went to 14 v, so according to him my alternator is good (and so is my battery). Do you think it could have something to do with the starter motor, like how it's a possible cause in the manual?
Old Sep 12, 2020 | 05:46 PM
MStrike's Avatar
MStrike
Here are some pictures of the camshaft position sensors' wires on the passenger (https://ibb.co/album/3vNv7j) & driver's (https://ibb.co/album/vsvMFm) sides.
Old Sep 12, 2020 | 06:35 PM
juster's Avatar
juster
Those wires on the first picture look like they are about to break off and there is no sheathing. Look how the plug is twisted in the 2nd picture you took of the first connector. It looks like the wires touch when it is twisted like that. A good thing about this is now you have an easy spot to test the wiring to the connectors from the ECU. Yea those plugs look bad where the wires are going into them. Plug them back in but make sure none of the wires are touching each other. Reset computer and give it another go.
Old Sep 12, 2020 | 07:17 PM
MStrike's Avatar
MStrike
Hey, just wanted to say that I really appreciate the constant help. So, from my understanding, first try to position the wires in a position where they are not twisted together and, if that doesn't work, then aim find a new wiring harness as those are starting to become unsheathed? I attempted to look up videos regarding the CPS wires but I have been unable to find much about the actual wires themselves.
G37xsnewguy
General Tech Questions
Oct 29, 2017 05:58 PM
VQ37V8R
Sep 28, 2017 11:12 PM
UCLAG37
Sep 20, 2014 05:47 PM
NeverBoneStock
Apr 23, 2012 09:12 AM
