Help What sensor is above/behind the transmission pan?
Old Jun 5, 2020 | 03:44 PM
dirtnapper56's Avatar
dirtnapper56
Unhappy What sensor is above/behind the transmission pan?
I am leaking fluid from my transmission right above/behind the transmission pan, and it seems to be coming out of where there is a sensor screwed in with a wire harness connected to it. I'm not sure if it maybe just came loose or is now broken, but that's where it's leaking from. I'm looking at parts diagrams and can't seem to find the correct part. It looks like it has a C clip around it as well, if that helps to identify it. I touch it and it almost feels like it is free floating, so I am assuming there is a seal there that is now broken.
That would explain why my transmission has been feeling a little jerky lately... lol
No pics as of yet, have to get under the car again and take another look.
Old Jun 5, 2020 | 04:09 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Are you referring to this guy:
If so, that is the A/T assembly connector- basically the connector for the TCM. Don't remove the clip. Once the clip is removed the connector will drop down into the tranny.
Old Jun 5, 2020 | 06:34 PM
dirtnapper56
actually no, the connector i am seeing under here is on the rear, right behind/above the transmission pan. But it is exactly the same style of connector/sensor as that! Could just be because my model is a little older?
Old Jun 5, 2020 | 07:00 PM
ILM-NC G37S
Nearest I can tell, if it is a 10-pin connector, then that is the TCM connector. All copies of my FSM for the 7AT (2010, 2012, 2014) show only one (1) electrical connector. Even the 2018 Q60 shows just one (1) connector. That has to be the one you are having issues with.
Old Jun 5, 2020 | 07:16 PM
dirtnapper56
Nearest I can tell, if it is a 10-pin connector, then that is the TCM connector. All copies of my FSM for the 7AT (2010, 2012, 2014) show only one (1) electrical connector (unless I al totally missing something).
that makes sense to me. Why would it be leaking. Is there a seal there that may have ruptured?
Old Jun 5, 2020 | 07:44 PM
ILM-NC G37S
More than likely the o-ring took a crap. From the 2018 FSM:
Not a hard fix, but a PITA none the less.
EDIT: the part is called a TERMINAL JOINT and is p/n: 24361-90X00. They cost ≈$30-50 depending on where you buy.
You could probably find a suitable o-ring for a fraction of the cost that will work just the same.
Old Jun 6, 2020 | 08:04 AM
SonicVQ's Avatar
SonicVQ
Before you start to buy parts or disassemble, have a close look at the transmission cooler lines that are right next to the connector. (Where the red plugs are in the above pic)
They are under pressure and if there is a small leak, it could spray onto the connector, making it look like the connector is leaking.
It is very unlikely it is leaking at the connector, since there isn't any pressure behind it.
The inside of the transmission is vented to the atmosphere.
Old Jun 6, 2020 | 09:23 AM
ILM-NC G37S
Good advice. Never thought of the cooler lines....
Old Jun 10, 2020 | 03:02 PM
dirtnapper56
Hey all here's an update. It's dry now somehow... You can see the sensor pictured here and there are no lines for cooling near it, just some sort of bracket type thing or maybe a shift linkage of sorts. Not sure if that means there's no fluid in there or what! But I think this is the torque converter, not the transmission?? Anybody have some insight?
Old Jun 10, 2020 | 04:00 PM
ILM-NC G37S
I did not realize you had a G37X- AWD- car!!! That said, I am 99.9% sure that your "mystery connector" is for the AWD SOLENOID. This solenoid controls the electronic coupling of your AWD system. According to the FSM, if this fails you have to replace the entire coupling.
Personally, I would leave it alone. Unless fluid is gushing out, or you have other symptoms, leave it be. Maybe some of our AWD members will have other input.
Old Jun 10, 2020 | 04:05 PM
SonicVQ's Avatar
SonicVQ
That is the transfer unit.
It is bolted to the rear of the transmission and provides drive to the front differential, then the front wheels.
To my eye, the leak looks to be above the electrical connector.
If it isn't dripping, I wouldn't worry it. Just check the level:
https://www.myg37.com/forums/engine-...firmation.html
8thgenchik
Intake and Exhaust
Nov 24, 2022 12:57 PM
venzz
13
Jun 9, 2020 09:33 PM
apexi957
Intake and Exhaust
Apr 20, 2016 07:18 PM
Aryrm Cheng
Intake and Exhaust
Sep 11, 2013 04:21 PM
