Broken Intake Resonator
Old Nov 15, 2019 | 01:03 PM
G.AWD.zilla's Avatar
G.AWD.zilla
Originally Posted by Baadnewsburr
with the hole in the system you will probably get a CEL at some point when the system does a check, maybe after 500-1000miles/kms or something..probably gonna be a P4XX code, it may cause a lean condtion if the system tries to compensate...for the unmetered air entering post MAF
You can delete the PCV system (go catchcan/open or closed loop etc...) but you can also just bridge that connection (the little box is just a resonator) with some standard PCV hose to reseal the system...or you can put up a WTB in the classifieds I'm sure lots of ppl have oems lying around
Would something like this work, do you think?
https://www.idealvac.com/Adapter-Pla...ree/pp/P103672
Old Nov 15, 2019 | 01:06 PM
Baadnewsburr's Avatar
Baadnewsburr
yeah, if its the right diameter (not sure about it) should work throw some hose clamps on it and it should hold...
Old Nov 18, 2019 | 03:08 PM
G.AWD.zilla
Came up with a fix over the weekend:
Total cost: $0.65
Seems to be holding up for now. Will keep an eye on it and report back after some more miles.
May end up going back to OEM if I feel it necessary.
Thanks all for the help!
Old Nov 18, 2019 | 03:09 PM
PNW_IPL's Avatar
PNW_IPL
Total cost: $0.65
Wheres the house from the other side plugin? That hose from otherside is to help equalize pressure between the two banks.
Edit looks like VHR has separate pcv systems vs single on my HR sedan. Carry on. Good fix.
Old Nov 18, 2019 | 03:21 PM
G.AWD.zilla
Sorry. Not sure I'm following your question.
There were only 2 hoses:
1 from rocker cover to the resonator
1 from resonator to Intake
Both are still intact, never removed.
You talking about a different hose?
Old Nov 18, 2019 | 03:23 PM
PNW_IPL's Avatar
PNW_IPL
From what I see your little box that broke has two openings?
On my HR I have 3. One to valve cover one to intake pipe and one that has a long hose connected to the other side intake pipe. Looks like a different setup from HR to VHR. that's why I initially said a T fitting.
Old Nov 18, 2019 | 03:26 PM
PNW_IPL's Avatar
PNW_IPL
Old Nov 18, 2019 | 03:28 PM
G.AWD.zilla
Well I'll be.. that is different. Interesting.
Yep, only ever had 2.
Wonder why you have 3...
Old Nov 18, 2019 | 03:30 PM
PNW_IPL's Avatar
PNW_IPL
The HR has only one pcv system so that third is to equalize pressure between the two. Since you have two pcv valves you dont need a hose connecting the two banks.
Old Feb 18, 2024 | 02:34 PM
Luckybrwnz's Avatar
Luckybrwnz
Did this work?
Did this work. Having the same issue on my Infiniti and need help. Thanks
Total cost: $0.65
Old May 13, 2024 | 12:07 AM
kc_pig's Avatar
kc_pig
Just snapped mine off today too replacing both PCVs...... Going tomorrow to try the elbow.
JustROLLIN
Jul 13, 2018 07:19 AM
TJHG37S
Intake and Exhaust
17
Jun 15, 2009 01:10 PM
Gyoza
Intake and Exhaust
Mar 28, 2009 09:05 PM
jc562
Intake and Exhaust
Feb 28, 2009 02:22 AM
camp3r
Intake and Exhaust
Feb 25, 2008 11:48 PM
