Issue after ITB13-019a
Old Aug 19, 2018 | 01:22 AM
GLife14's Avatar
GLife14
Recently had the ITB13-019a update after I had a complaint of a harsh downshifting. Dealer did not find anything abnormal but found the P0710 code stored and updated per the TSB. As it is a 2013, it already had the update from factory for the lag issue discussed in length in this forum. This update improved what I thought was already "updated" in terms of the sluggishness/lag.
The issue is the update took away the aggressiveness of the DS mode. It only rev matches under heavier braking and the downshifts, whether rev-matching or downshifting in DS, are now quieter. I thought about replacing air filters, cleaning MAF and disconnecting battery overnight but not sure if that would help.
Can anyone else who has this update to their 2013 chime in? Also, is it possible to revert to older software on the TCM? Thank you.
Old Aug 19, 2018 | 07:57 PM
codeflux's Avatar
codeflux
20 Year Member
Yep, I have the same update and noticed the same thing you did. Not sure if dealer will revert for you, and even if they do that it'll be free.
Old Aug 20, 2018 | 12:11 PM
Baadnewsburr's Avatar
Baadnewsburr
you may just need to drive it for a while to "relearn" your driving style to get it to behave the way it used to in the DS mode again
Old Aug 21, 2018 | 01:57 PM
GLife14's Avatar
GLife14
Hopefully. I have driven about 1k since but it was all mostly in D , not DS. Dealer said it may need to relearn as well and that I could NOT go back to previous software on the TCM.
Old Aug 21, 2018 | 01:58 PM
GLife14's Avatar
GLife14
How long has it been since the update?
SON415
Jun 2, 2015 05:27 PM
venzz
TSB - Technical Bulletins
Jun 2, 2013 07:30 PM
alhayem
Intake and Exhaust
13
Jun 27, 2011 02:28 PM
rossab
19
May 5, 2011 08:14 AM
Moofer
14
Oct 27, 2010 07:31 PM
