2012 infiniti G37xS Coupe issues?
Old Jul 27, 2018 | 08:22 PM
Coltrane1's Avatar
Coltrane1
Does a 2012 model have the paper gasket issue that caused so many issues for earlier model sedans?
I'm considering a 2012 X sport coupe with 60k miles. Any issues I need to be aware of? Thanks in advance.
Old Jul 27, 2018 | 11:12 PM
2012 models have the revised gasket, should be no other significant issues.
Old Jul 28, 2018 | 01:15 PM
takemorepills's Avatar
takemorepills
I just bought a 2014 AWD coupe. In my research, everything I found said the 2012 model year (as in, could have been made late 2011) incorporated the new gasket specification. You should be good to go. Same as you, I limited my search to 2012+ cars.
Old May 11, 2021 | 03:15 AM
Mikey997's Avatar
Mikey997
Does anybody know if there’s a way to find out if there is any late model year 2011’s that had the gasket revision done? And if so what was the manufacture date or Vin number or way to tell? Date of manufacture etc.
Old May 12, 2021 | 12:49 AM
jpowersjr2's Avatar
jpowersjr2
That might be something only a knowledgeable dealer would be able to find out.
Side note: 2012 is when they fixed the gasket issue and used a better material. However, in some rare cases some cars had the gasket bolts back out due to them being improperly torqued down from the factory.
EPS tuning sells a kit to replace everything if it's ever needed.
Mikey997
May 12, 2021 07:10 AM
agent
Jul 15, 2014 12:36 PM
Hedgehog25
The M - Spot
16
Nov 13, 2013 07:14 PM
jjkusaf
Future Models
24
Jun 25, 2011 09:38 PM
Mike S.
Jan 22, 2011 05:29 AM
