Help with Overheating
Old Jul 26, 2018 | 08:34 PM
Jeebus's Avatar
Jeebus
So I went out for lunch today and noticed that the Engine Temp went well over H, I opened the hood and looked at the coolant and it was all gone. So I just went to buy some, but after letting the car rest I started the car up and the radiator hose is burning hot and the car was literally on for 20 seconds. Can anyone guide me to what could be the issue I can't make it to the dealership until Monday. The engine is very hot as well and has a a smell of a kind of burned oil.
Old Jul 26, 2018 | 10:47 PM
Could be several things from head gasket, heater core, radiator leak, water pump, radiator cap, hose fittings. Really need to have the system tested at a shop if there's nothing obvious. Any coolant leaks that you're able to ID? I wouldn't drive it in it's current state,
G/L
Old Jul 26, 2018 | 11:17 PM
Jeebus's Avatar
Jeebus
G/L
As far as I can tell I get leaking from the AC but I assume that's pretty normal for most car especially here in Florida, this started to happen cause the temperature in Florida is like 95+ everyday so assume that doesn't help much either. But awhile ago a tech did tell me I had a coolant leak, but at another dealership they said they didn't see any. I also now a check engine light... this really sucks cause I don't wanna pay for anything over $500 especially since I am planning on a Q60RS later this year.
Old Jul 27, 2018 | 08:32 AM
telcoman's Avatar
telcoman
Originally Posted by Jeebus
...t awhile ago a tech did tell me I had a coolant leak, but at another dealership they said they didn't see any. I also now a check engine light... this really sucks cause I don't wanna pay for anything over $500 especially since I am planning on a Q60RS later this year.
Why didn't you request a pressure test after you were told you had a coolant leak?
Telcoman
Old Jul 27, 2018 | 09:01 AM
Need to pull the code for that engine light, hopefully nothing serious resulted from the overheating. Coolant leaks can be tricky to detect sometimes, especially if it's leaking from an area where the coolant will evaporate (like hot exhaust parts) and not leave an obvious puddle. Also be sure to check the oil dipstick for any milky residue since it could be leaking into the motor.
Old Jul 27, 2018 | 10:13 PM
crookncastle's Avatar
crookncastle
is there a reason why you can't tow your car to the dealer or shop to have it checked out? they don't need you to be there to inspect the car. your radiator hose may be burning hot due to the engine lacking coolant and possibly now it has a air bubble which in itself will cause the engine to overheat too. it would be best to have the cooling sys pressure tested, thermostat checked, and cooling fan operation tested. as far as the burning smell, it may be a possible coolant leak and fluid is being burnt up by the hot engine or exhaust.
Old Jul 28, 2018 | 12:04 AM
Jeebus's Avatar
Jeebus
So I did take it to the dealership, got a chance to get off early. Dropped the car off and it's a bad water pump from what the advisor told me.. which is going to cost $2k..
Old Jul 28, 2018 | 09:11 AM
Ouch! What year is your G? Not 100% sure if they would automatically change those oil gallery gaskets that are prone to fail on pre 2012 models when replacing the water pump. If yours is pre 2012 I would make sure that those gaskets are changed while they're in there replacing the pump, would hate to have to go through another $2k if those gaskets crap out.
G/L
Old Jul 28, 2018 | 02:00 PM
Jeebus's Avatar
Jeebus
G/L
Mine is 2011, at this point I'm not sure if I want to shell out $2k right now. The only problem is I don't think there are many well qualified mechanics in my area which is why it's such a hard choice for me. Do I pay the $2k and know that I'm backed by Infiniti if anything goes wrong, or go to a mechanic and get charged $1k and something might go wrong especially if they're not used to working on this water pump which isn't located like most traditional car.
Old Jul 28, 2018 | 05:07 PM
slartibartfast's Avatar
slartibartfast
Hunt around for a shop specialing in Z cars.
Old Jul 29, 2018 | 12:02 AM
This^^ or at least give a Nissan dealer a go and see what they quote for the repair, typically cheaper than Infiniti, and they will have the techs versed on the VQ motor.
keithnellie
Oct 2, 2022 06:08 PM
dany_rizkallah
Jul 16, 2018 03:12 PM
fysemi
May 9, 2018 09:54 PM
ahmed.zakut
General Tech Questions
32
Feb 24, 2014 08:07 PM
kaoticdemize
Oct 16, 2011 03:24 PM
