Help permanent error codes
Hello,
When I bought my G37 2013 the SES light. There were a few irrelevant mistakes, but after they were deleted, SES stopped lighting.
The car sailed from the USA to Germany and probably the battery was completely broken. I suspect that this had a significant impact on the appearance of "permanent error codes". I can not delete them. I did the procedure with the gas pedal depressed, after disconnecting the battery I pressed the brake pedal to completely lower the ECU voltage.
With no effect. The errors that sit are P0011 (probably from old oil), P0603 (I bet that from the previous battery).
Does anyone have an idea how to clear these error codes?
Best regards, Paweł
Best regards, Paweł
Permanent codes can not be cleared by a scanner. When the detected fault is repaired, then the ECU clears them.
I can't see "old oil" causing a P0011. Change the oil/filter and check the oil pressure to see if the rear timing gasket is leaking. (idle: >14 psi at 80C)
The P0603 is not caused by the battery being disconnected. It is an ECM power supply circuit problem or bad ECU. Has any electrical work been done on the car? (after market radio/amps)
Something was just done electrically because the car had collisions in the front. Unfortunately, I do not know what it could have been. As for P0011, in my year, these gaskets have already been reinforced. The most annoying, however, is that when the car warms up, adding gas in the range of 900-1100 rpm, the turnover drops to 500 and the car is choking.
thanks, in that case you think that these unfortunate gaskets may be? I have 2013 and it should be ok: /
There is no icon on the dashboard regarding the low pressure. How do I start the car in the morning is a problem with engine revs. revolutions reach up to 1,100 and fall below 500 when driving slowly. This happens until the SES lights up. Then the car probably goes into emergency mode and the maximum speed is 3500. The strangest thing is that then it goes smoothly, the speed does not drop and the ignition does not fall out. At that time there is no error 0011 0021 and 0534 (I think). The error regarding low oil pressure appears only as the car goes crazy with low revs.
Hello again, yesterday I pulled out both valves VVL. I have connected them under the battery for a short time and it seems to work properly.
https://www.youtube.com/watch?v=q9NV...ature=youtu.be
Just in case, I cleaned the VVL well.
The car all the time after the ignition is waving from revolutions in the range of 900 - 1200. While driving, sometimes only error p0300, sometimes p0011 or both with p0021 appears. After that, the car enters emergency mode and works nicely but only up to 3500 rpm
Detailed Image
Car Care & Detailing
45
04-29-2011 02:18 PM
