Throttle Body Coolant Hose
Old Apr 8, 2018 | 01:48 AM
jkorchemniy's Avatar
jkorchemniy
I recently found a leak coming from a coolant hose attached to the throttle body on my 2012 G37 sedan (shown in pic... also I fully realize how dusty my motor is ). It seems like a fairly simple fix, is there measures I have to take prior to disconnecting and replacing the hose (e.g. Coolant drain) ? Or can I disconnect w/o coolant drain?
Any input is appreciated
- Joe
Old Apr 10, 2018 | 10:18 PM
Джон's Avatar
Джон
Just disconnect it and let the coolant go where it goes. Wash off the coolant and dust with water after you install the new hose
Old Apr 11, 2018 | 12:18 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Maybe baking soda/water mix to remove the residue?
Old Apr 11, 2018 | 12:54 AM
hobbs's Avatar
hobbs
That is for battery corrosion.
Old Apr 11, 2018 | 11:27 PM
Once you remove the hose from the barb just a light sanding w/ some steel wool or a scotchbrite pad should clean up any buildup, just check for any pitting that may be penetrating into the hose mount, should be in fine shape if it hasn't been too long.
Mattlorentzoe
Dec 26, 2020 06:03 PM
JakeG37
Apr 20, 2018 12:05 PM
tscani
Oct 25, 2016 07:45 PM
dwb993
Sep 26, 2016 09:10 PM
effeckt-
Intake and Exhaust
Sep 14, 2016 05:11 PM
