Engine light on
Old Aug 13, 2017 | 08:13 PM
summerwind's Avatar
summerwind
Engine light on
2012 G37 sedan 60K miles light just came on couple of days ago and stays on. Will take car in. This a common problem? Appreciate your comments.
Old Aug 13, 2017 | 09:23 PM
hurleyguys's Avatar
hurleyguys
hard to say. go and pull the code with an OBDII scanner and tell us what it says
Old Aug 13, 2017 | 11:45 PM
Most auto part shops will have the scanner that they can check the code for free. It can be something as minor as a loose gas cap or something serious like low oil pressure.
Old Aug 14, 2017 | 01:13 AM
crookncastle's Avatar
crookncastle
check engine lights can come on for hundreds of reasons. whatever it is if its a emissions related component failure it will be covered under the federal emissions extended warranty.
Old Aug 16, 2017 | 08:31 PM
summerwind's Avatar
summerwind
The car's going in Friday. I'll be back here to give you the code. Thanks!
Old Aug 16, 2017 | 08:42 PM
saywat?'s Avatar
saywat?
scanners are so cheap now less than $20 esp on amazon everyone should have one
summerwind's Avatar
summerwind
Thanks crookncastle. The did go in for emission testing at a state-approved testing center in Milwaukee. Trying to recall if the engine light came on after the testing. The warranty you speak about is only on federal emission testing?
Old Aug 16, 2017 | 08:43 PM
summerwind's Avatar
summerwind
Saw an advertorial online AOL couple of days ago about FIXD or something like that. Anyone heardof it?
Old Aug 16, 2017 | 11:03 PM
Strokelessone's Avatar
Strokelessone
Just go to an Autozone, or Advanced auto, they will check it for free. My light went on, and all it needed was a new gas cap, the old one wouldn't seal, kicked on the engine light
Old Aug 18, 2017 | 06:31 PM
summerwind's Avatar
summerwind
Thanks! Will keep in mind.
Old Aug 18, 2017 | 06:40 PM
summerwind's Avatar
summerwind
hurleyguys,
really strange. been driving around for over a week with engine light on. Made appmt at Infiniti for today. On the way there up until I parked the car the light was on. The service consultant comes out to drive car in and no light. He didn't think it necessary to run the scan bc engine light was not on. Go figure.
Old Aug 18, 2017 | 07:51 PM
Bommerang's Avatar
Bommerang
You can still get it scanned at Autozone or get your own scanner, it'll show the saved/pending code that caused the light to occur in the first place.
Old Aug 18, 2017 | 08:16 PM
hurleyguys's Avatar
hurleyguys
ya like bommerang said have it scanned anyway. it will have saved codes in your ECU. so what it was before you just write it off and say it was nothing.
Old Aug 18, 2017 | 08:39 PM
summerwind's Avatar
summerwind
Thanks hurleyguys, will do.
Jan 10, 2026 02:16 AM
G37xsfun
Oct 1, 2016 02:19 AM
Quiver
Sep 28, 2016 10:07 AM
