Auto transmission shifts early...
Old Jul 27, 2017 | 07:16 AM
Rekorb's Avatar
Rekorb
When tracking my 2013 G37S in the "manual" mode with the seven speed automatic the transmission will upshift well before red line. I lose the top end rpms in the power band and this can happen sometimes around 6000 rpm. I am definitely in the manual mode and upshifting early ruins the performance. What gives?
Old Jul 27, 2017 | 08:14 AM
RMB5190's Avatar
RMB5190
How is it shifting if it's in manual mode? My car will bang of the limiter unless I shift. You're using the paddles to shift or the shifter right? Want to make sure you aren't talking about "DS" mode
Old Jul 27, 2017 | 12:18 PM
Victory's Avatar
Victory
Are you in manual or DS and are you at WOT?
Old Jul 27, 2017 | 04:31 PM
kroy's Avatar
kroy
I've noticed my DS mode can shift before redline; like 7300ish at times.
In manual mode, if you have a stock tune car, it will hit a safety rev limiter prior to 7500. Even if you physically shift at like 7400, it will still give out first. Gotta shift at like 7300.
Old Jul 30, 2017 | 10:44 AM
nethole's Avatar
nethole
question does it 'always do this'? Or does it do it after 10-15 minutes on the track? (asking from a heat perspective). From your post count, I'm assuming you have not modified the vehicle (meaning, you have not replaced the radiator)
Old Jul 30, 2017 | 11:15 AM
Victory's Avatar
Victory
TBH, looking at the power curve for these cars, you're probably better off shifting at 7300. The power drops off precipitously above 7000 rpm
Jan 10, 2026 02:16 AM
Koval88
26
Aug 4, 2023 03:54 PM
Devilsfan118
30
Nov 12, 2019 01:14 PM
b2autodesigns
Interior/Exterior Items
140
Mar 29, 2018 12:14 PM
Eyeshield25
Drivetrain
Oct 14, 2016 10:31 AM
