Help Stillen Gen 3 Intakes with a DEI reflect a Gold wrap
Old Dec 7, 2016 | 10:55 AM
Kris9884's Avatar
Kris9884
I wish I did the intake before the exhaust, I never heard a difference since the RTP's, y pipe and mufflers were over bearing. Oh well
Old Dec 7, 2016 | 11:18 AM
2011-G's Avatar
2011-G
hahaha yeah - BTW would you recommend resonated test pipes? I heard the rasp gets unbearable after removing the cats. What's your take on it?
Old Dec 7, 2016 | 12:22 PM
Kris9884's Avatar
Kris9884
Yeah, definitely resonated test pipes lol. I still get some rasp at certain higher RPM's but not at all while driving normal and I think its more due to the y-pipe, very tolerable.
Old Dec 7, 2016 | 05:37 PM
2011-G's Avatar
2011-G
Yeah prior to this I owned a G35X and had a AEM cold air intake with Megan racing Y pipe and removed the resonators and muffler (Straight pipe) and that rasp was soooooo nasty but the car sounded so aggressive on the lower RPMs.
I was thinking maybe the rasp is there because I removed the resonator. I didn't know that Y pipe caused it. I am going with GTHaus Y pipe in the future, not sure how it's gonna sound but I will find out lol.
Old Dec 8, 2016 | 11:02 PM
Ape Factory's Avatar
Ape Factory
The air is traveling way too fast through the intake tubes to heat the entire mass of air flowing through them. We're talking a few hundredths of a second for molecules to go from entering the filter to entering the throttle body. Wrapping them is a waste of time.
Old Dec 12, 2016 | 08:37 AM
PongSanity's Avatar
PongSanity
yet they're countless before and after with stillen intakes and admin tuning 3 inch cold air intakes yielding big power over stock. denser air/lower temps = more power. i got Art pipes on my G and i get no rasp... it sounds beautiful.... could barely tell that i changed from fast intentions high flow cats.
Old Dec 12, 2016 | 05:33 PM
2011-G's Avatar
2011-G
^^^ Nice - Is your car running more lean after the ART pipes? Did you check your A/F ratio
Old Dec 13, 2016 | 11:38 AM
Kris9884's Avatar
Kris9884
In my case, the aftermarket y pipe has a single 3" outlet that mates up to the stock mid pipe that I think is 2.5". So, the instant forced downsize in diameter is the cause of the rasp. Not having cat's certainly doesn't help either though lol
Old Dec 13, 2016 | 12:46 PM
SonicVQ's Avatar
SonicVQ
I agree, but at low speeds it may help to reduce the intake tube heat soak and IAT (intake air temp).
Old Dec 13, 2016 | 03:01 PM
Kris9884's Avatar
Kris9884
May not be any real benefits besides it looking cool but, it certainly cant hurt anything..
Old Dec 14, 2016 | 09:19 AM
PongSanity's Avatar
PongSanity
Yes it did lean out. I also ported my intake manifolds. Return imminent.
