Output Shaft Seal Leaking
Old Mar 10, 2016 | 06:30 PM
NSH PREDS's Avatar
NSH PREDS
Has anyone had any experience with the output shaft seal leaking in/around the transfer case? Is it a common occurrence on X sedans or with G's in general?
If so, I figure that the 60k mile powertrain warranty should cover the expense of replacing it?
Old Mar 11, 2016 | 10:21 AM
si_driver's Avatar
si_driver
Not sure if it is common or not, however, mine was also leaking at around 38,000 miles. and was fixed by the dealer under warranty.
Old Nov 20, 2016 | 07:29 PM
rpkg37xs's Avatar
rpkg37xs
Does this look like the seal on the front drive shaft is bad?
Old Jun 8, 2023 | 10:25 AM
Gm_mtz's Avatar
Gm_mtz
Update
Hey I was wondering if you ever replaced the seal from the picture? I’m planing too
rlb
Oct 7, 2021 02:12 PM
aznviper37
Nov 27, 2017 05:11 PM
skmonsta
36
Jun 17, 2014 11:53 AM
mariosg37
14
Dec 4, 2013 10:52 PM
ramet
General Tech Questions
Nov 15, 2013 09:50 AM
