Infiniti G37 engine revs up and down randomly
Old Feb 1, 2016 | 08:18 AM
InfinitiG37Ownr's Avatar
InfinitiG37Ownr
The car has not been started after a while due to a wreck. But when I removed all the damaged radiator parts in the front I got the car started. I had to replace the crankshaft sensor because it was broken from impact. When the car starts it gradually revs up and the randomly dips down to low rpms and revs up again. Basically car does not idle at a stable rpms. What could be the problem for this?
Old Feb 1, 2016 | 08:23 AM
micafd3s's Avatar
micafd3s
sounds like a vacuum leak..
Old Feb 1, 2016 | 09:02 AM
InfinitiG37Ownr
Any ways or ideas on how to fix a vacuum leak?
Old Feb 1, 2016 | 09:09 AM
Is this the same flood damaged car you were asking about rust issues in another thread?
Also, please post your threads in the appropriate place. The forum question and suggestion forum is not what you seem to think it is. Read what each forum is for and place your threads in the appropriate one so that people who might be able to help you sill actually see it.
And good luck with your car.
Old Feb 1, 2016 | 09:23 AM
Ricio1991's Avatar
Ricio1991
Thinking vacumn leak as well, mine did the same thing, never fixed if but for a vacumn leak you have to check if there's any holes in your air intake or something like that there must be a leak somewhere. Let me show you a video of my 08 coupe when it used to do that, I now have a sedan but this was my prior car
Old Feb 1, 2016 | 10:36 AM
InfinitiG37Ownr
Yes this looks like what mine is doing but mine goes up higher in the Rpms. Also when gassing it alittle it would choke and not rev like it should
Old Feb 1, 2016 | 02:32 PM
Ricio1991's Avatar
Ricio1991
Throttle bodies ever been cleaned?
Old Feb 2, 2016 | 05:14 PM
hooey_b's Avatar
hooey_b
^^^+1, then vacuum leak.
Old Feb 2, 2016 | 11:41 PM
InfinitiG37Ownr
I will look into it and clean them. I'll let you guys know what happens
Old Feb 11, 2016 | 10:57 AM
jwick's Avatar
jwick
Try the throttle body relearn procedure while your at it.
Old Feb 29, 2016 | 11:47 AM
akiradavis's Avatar
akiradavis
also, if you did clean them and it still occurs, check for vacuum leaks and then replace your throttle bodies. I tried cleaning them but replacing them finally stopped the idling issue
Jan Ondracek
Apr 8, 2024 07:09 PM
MR_L
MODDING 411
Sep 2, 2016 11:35 AM
Gary U
Jun 6, 2016 02:19 PM
G37LoverBaby
Mar 1, 2016 03:33 PM
m3clubracer
Feb 22, 2016 08:26 AM
