Southbend stage 2 daily clutch with billet steel 19lb flywheel HELP
Old Oct 10, 2015 | 10:51 AM
Mr.G's Avatar
Mr.G
I just installed the southbend stage 2 daily clutch with southbend billet steel 19lb flywheel, HD CSC and new master cylinder from ZSPEED and I wanted to see if anyone have this same setup on their g37s.
Everything is fine but I'm getting worried about the loud chatter noise when i put a load onto the car.
For example, I'm slowing down at a stop sign and put it on "N" and then pop it to 2nd at 5mph and start accelerating, it makes this harsh rattle chatter noise until i reach 2k rpm.
It even happens on first gear when I'm going from a dig but the noise goes away quicker then being on second gear.
I found this 350z video from youtube and I believe that I have the same problem.
Could anyone let me know if this is normal?
I'm just getting worried that my mechanic might of done a bad install...
But other than the noise at low rpms, it's fine and drives a lot better.
The chatter on idle also went away completely compared to stock.
Please let me know if anyone have this same problem after installing a new clutch with lighter flywheel.
Thanks.
J
Thanks.
Old Oct 10, 2015 | 12:07 PM
Thirty_Seven's Avatar
Thirty_Seven
Chatter of that nature is totally normal. It's caused by going form a very heavy dual-mass flywheel to a lightweight single-mass flywheel.
It's pretty much unavoidable when going aftermarket, although South Bend makes something called a "quiet disc" that is supposed to suppress the chatter. My car is in the shop right now getting a new clutch/flywheel with the silent disc option, so I can't comment on how well it works just yet.
Unfortunately, you'll have to live with it. But just know that it's completely normal.
Old Oct 10, 2015 | 10:23 PM
g_dc's Avatar
g_dc
I have the exact package on my G that I got installed a month ago. When I first drove it I was shocked as well but that is what flywheel chatter is. You have a lighter flywheel than stock OEM and once the car is under load, that sound and vibration and transmitted through the drivetrain.
TL;DR: flywheel chatter is normal going from dual mass to single mass flywheel
Old Oct 12, 2015 | 02:25 PM
Mr.G's Avatar
Mr.G
Thanks for the reply guys. I was freaking out when I heard that chatter under load in 1st and 2nd gear.
I guess I just need to change my driving style(STAY AT HIGH REVS) to avoid the noise.
Other then the chatter noise, it drives great...!!!
I could shift from 1st to 6th gear quickly and smooth a lot better compared to stock setup(lazy manual setup lol).
I got mine from Joe at zspeed. Thanks again Joe!
Now I regret selling all my parts(r2c intakes, hks hi power full exhaust, berk test pipes, kw v3 coils and volks gt30 20's in gold finish) after a new clutch/flywheel. =(
Old Oct 12, 2015 | 02:28 PM
Mr.G's Avatar
Mr.G
Thirty_Seven: I was looking at your pics and your plate holder caught my eyes.
SPLIT SECOND COLLISION. I'm guessing that you know Mike?
Whitestone bridge near Malba?
Old Oct 12, 2015 | 02:43 PM
SlateBlue G's Avatar
SlateBlue G
your clutch is messed up LOL. ok i'll stop
Old Oct 12, 2015 | 03:12 PM
Thirty_Seven
Lol yeah Mike is a good friend except for the fact that he steals my license plate frames and puts his on every time he's near my car haha.
And yeah that's where those pics were taken. I'm guessing you're in the area too?
Old Oct 12, 2015 | 03:40 PM
SlateBlue G
Mr. G and I are from the same area except he's a noob
Old Dec 8, 2015 | 11:08 PM
steez's Avatar
steez
Damn is the clutch chatter that bad??
I'm thinking of the Southbend Stage 3 package.
Seems like the Quiet Disk option for $50 is well worth it now..
On stock I hear a bit of noise at idle when I press clutch.
I only noticed it last 6 months though. Not sure if its same clutch chatter described. I don't hear it while driving just in 1st before blending.
Old Dec 9, 2015 | 12:37 AM
Thirty_Seven
Here's my review of the "quiet disc" option:
https://www.myg37.com/forums/drivetr...sc-option.html
Short answer is it's WELL worth it.
allen88909
Southern California
Mar 8, 2016 04:12 PM
BurtoN86
Oct 28, 2015 07:56 PM
desertmike680
Oct 12, 2015 08:00 PM
SheLLz
Oct 6, 2015 08:09 PM
SheLLz
Sep 24, 2015 08:02 PM
