RJM Performance Clutch Pedal Assembly
Old Sep 5, 2015 | 08:15 PM
  #121
RexHavoc's Avatar
RexHavoc
modesty, FTW
You mean flappy paddles FTW. I'm on my second set now; the CF paddles shift soooo smooooth.... (Or something like that)
Old Sep 9, 2015 | 04:50 PM
  #122
grocerylist's Avatar
grocerylist
I installed my RJM pedal not quite a year ago but left it at the 70% clockwise (instruction install) settings and hadn't tweaked it since then because to be honest it's kind of a pain in the *** to adjust (both sensors as well as untightening the allen screw to adjust the red ****). I noticed a little improvement but wasn't overly impressed.
After revisiting this thread I decided to play with the settings and try the per Rochester's setting 0% with 1 turn clockwise and I now definitely notice that the clutch engagement/release is far smoother. In adjusting the **** I also noticed that the sensor that detects full clutch pedal press was loose, so it's good I made this adjustment. I tightened both sensors up again, but I may have to check these about every 6 months so I'm not potentially stranded with a car that won't start.
Old Sep 9, 2015 | 05:11 PM
  #123
Thirty_Seven's Avatar
Thirty_Seven
Read through the installation instructions a few times and I have a couple questions.
My AFP **** is at 70% and I want to turn it to 100%. What other adjustments need to be made? I'm a little unclear about that part.
Old Sep 9, 2015 | 05:27 PM
  #124
The two electrical switches (cruise and ignition) may need to be re-aligned if you adjust the main ****. It's not that bad, and they still seem to work well even if there's a fair amount of sloppy fitment. These are adjustments so that the switches function properly, and have nothing to do with the pedal engagement... unless the cruise switch is compromising the pedal.
AFAIK
I prefer a wide engagement, and a high pedal. It's just really easy to drive that way.
Old Sep 11, 2015 | 01:27 PM
  #125
Thirty_Seven
AFAIK
Alright cool. Thanks
So as long as my car starts and cruise control disables when the clutch is depressed then they're aligned correctly I assume?
Old Sep 11, 2015 | 01:45 PM
  #126
Well, no. You can assume that they're aligned well enough to function, but to be aligned optimally, you need to just get down there and look at things. It all becomes clear when you look at it.
Old Sep 12, 2015 | 05:29 PM
  #127
JSolo's Avatar
JSolo
Just say no!!!!!
^^Excessive clutch wear can result from incorrect switch positioning and/or difficulty engaging in gear.
Old Sep 13, 2015 | 09:17 PM
  #128
ToXIc's Avatar
ToXIc
installed mine today, took about 2 hrs. i'm in love with the car again. was suppose to be my 1st mod but got side tracked with the spring swap. i'm been hating the pedal ever since i got accustomed to it.
the RJM arm is the best quality engineering and parts! i did two turns back and on the clutch rod turned it back till it was flush with the fork. Got engagement around 1.5-2" off the floor
one thing tho.. i can really hear that blasted throw out bearing now more than before.
Old Nov 8, 2015 | 04:43 PM
  #129
ToXIc's Avatar
ToXIc
Ok so I've been using this for a couple of weeks now. Have it set at around 90% (one turn from all the way counter clockwise) and lately it doesn't feel as off the floor as it used to. I've rechecked all the bolts and adjustments and it's feeling like stock again with all the annoying symptoms. Any ideas guys?
Old Nov 8, 2015 | 04:51 PM
  #130
Mine's been installed for going on 4 months, and I still have moments when I'm aware of how much better this is than before.
You say "off the floor", which is a mechanical adjustment of the three bolts that allow you to set the pedal height. So while those bolts might feel tight, it could also have slipped.
Old Nov 8, 2015 | 04:54 PM
  #131
ToXIc's Avatar
ToXIc
i've checked everything its all tight, "off the floor" meaning the engagement point is alot higher than when i 1st locked it in.
i am correct in dialing it back all the way left before turning it once back correct?
Old Nov 8, 2015 | 06:24 PM
  #132
That's my understanding... counter-clockwise provides the widest engagement, and full clockwise would be the same as OEM, just further down the pedal. Given that's how you locked it in (with the allenhead locking bolt), I don't see how the engagement could be any closer to top-of-pedal than the design allows.
Wish I knew what to tell you. Contact Ryan at RJM and discuss it with him. My experience is that he's really open to dialog, and would gladly give you advice.
Old Nov 8, 2015 | 06:49 PM
  #133
ToXIc's Avatar
ToXIc
Will do thx.
Old Dec 18, 2015 | 11:34 AM
  #134
ToXIc's Avatar
ToXIc
so figured out my issue a few weeks back.. in all the adjusting tuning.. i forgot along the way that i have to push in the pedal 1/2 way before locking in the adjustment ****.
i've also adjusted the hell out of this thing to find where i liked it.
**** from 1-3 turns clockwise
pedal height in relation to the brake pedal
and finally settled on 2.5 turns clockwise and height level to the brake (after the freeplay). i choose this based on the engagement high, amount of engagement and also in relation to the feel of the gear and stick engagement (how easily it was to get the car into gear). Since i have a SS the two adjustments did play a part in gear engagement.
also in the numerous adjustments i began stretching pedal bolts to breaking..
found exact replacement in HomeDepot bolt isle look in the loose bolt bins for ADA
Old Dec 18, 2015 | 12:40 PM
  #135
Nice bit of fine-tuning you did there. And pretty cool to have a device that let's you do it.
I can honestly say that I'm far enough removed from the OEM clutch pedal that I can no longer remember what it was like. The new normal is just normal now, and the only thing I can remember is how happy I was with the mod afterwards.
And Toxic, you're right about over-torquing the pedal bolts. I do recall thinking like that could easily happen.
