car won't start troubles
Old Apr 26, 2015 | 03:18 PM
astat4's Avatar
astat4
To begin with sorry if this is not the adequate place to post this here but I figured since it's about G37..
The story goes. I bought this car monday 2008 G37s manual 10k miles. Picked it up Wednesday with no problems, 1st day of driving as soon as I got close to my house the serpentine belt tore on me. No biggie I bought a new one and replaced it.. After that belt tore all these problem started.. for some reason the oil light would come off and on. But more like a flicker Like something was loose.. and it went away. Well 3rd day of having the car drove in the morning to work fine No problems. Lunch came around and I was heading to lunch started up fine, threw 1st gear no problem. Threw 2nd I heard a noise. Like a plastic vibrating or something And the engine died..
Car cranks over but does not start. Car throws no codes, already checked it with A scanner. I read for a bit and alotta people say the 08 g37s have battery issues. So just to clear my mind I took it to oriellys and it tested bad. They showed the machine. So no monkey business.
Could the battery be the problem that maybe all the electronics are not getting the 12v to start the engine but enough to crank it over.?.
Old Apr 26, 2015 | 03:56 PM
Ricio1991's Avatar
Ricio1991
Yes I believe so I also had a bad battery on mine and wouldn't start, it would try to start but wouldn't took it in and they determined it was bad and I replaced it and it started again with the new battery
telcoman's Avatar
telcoman
Test the battery yourself with a battery hydrometer.
There should be a date code on the battery. If it is the original battery or older than 4 years just replace it.
Telcoman
Old Apr 26, 2015 | 04:03 PM
astat4's Avatar
astat4
Telcoman
it is the original battery so it's a 08..7 years on it and maybe it's out already.. where could I get that battery hydrometer?
Old Apr 26, 2015 | 04:10 PM
2008G-Man's Avatar
2008G-Man
A 2008 with only 10k miles, that would trip the alarm bells for me. Try a volt meter or better yet, get a battery tester (good thing to have anyhow) that shows charging voltage, standby voltage and battery health under load. I got mine at Sears.
http://www.sears.com/actron-cp7614-1...6&blockType=G6
Old Apr 26, 2015 | 04:13 PM
astat4's Avatar
astat4
Sorry I musta forgot to put the 3.
It's 130k Miles lol.
Old Apr 26, 2015 | 05:45 PM
Ricio1991's Avatar
Ricio1991
If it's the original battery that explains everything definitely needs replacement, did good 7 years is plenty of life for a battery I'm sure you be fine with a new one just go for it
Old Apr 26, 2015 | 05:53 PM
astat4's Avatar
astat4
Wouldn't the car still turn on even by jump starting it tho? Cause it doesnt.
Old Apr 26, 2015 | 06:20 PM
Ricio1991's Avatar
Ricio1991
Good question well I'm not sure I mean if the battery is super dead I'm sure even by jump starting it won't start. It need enough juice to start it but I can't be sure. All I know I was at the end of my battery life because a couple months before that I got my battery recharged and it worked for a couple of months and then it happened again and I knew to change it and it was already past its 4 years. You might have something else wrong but if they determined your battery was gone most likely that will be the cause of it not starting in my opinion.
Old Apr 26, 2015 | 07:58 PM
astat4's Avatar
astat4
So I got a new battery and well....still same problem doesn't start just cranks over.
Guess I hope the warranty will fix this.
Old Apr 26, 2015 | 11:13 PM
crookncastle's Avatar
crookncastle
crank no start issues usually are the result of 2 symptoms. either you don't have fuel going to the engine or perhaps you lack spark for the ignition system. check if you have fuel pressure with a gauge. if pressure is good, move on to check the ignition system. check on the scanner if you are getting a crank sensor and cam sensor signal on live data reading as you crank your engine. if cam and crank sensor is providing signal output pull out a plug and coil and check to see if you are getting spark at the plug. if no spark is evident now you have to back track and diagnose why you are not getting primary ignition signal before the coil, which means you would need a etm of your make and model.
Old Apr 28, 2015 | 09:20 AM
astat4's Avatar
astat4
So the car was taken to the dealer and found out that it is in fact throwing codes it's throwing both cam bank codes and crank shaft. Spoke to the technician working on the car and he's guessing the car coulda jumped timing and skipped a tooth .. that the 37 motor are know for that.
Still not a confirmed diagnoses but that all he has as of right now.
Old May 4, 2015 | 10:02 AM
astat4's Avatar
astat4
Well update on this problem. The car did in fact did jump timing. So Nissan requested my warranty for a new engine to be installed..
Old May 4, 2015 | 11:28 AM
properdropper's Avatar
properdropper
just read this whole thread thats crazy man.. how does that even start to do that? anyways hope it all gets fixed for you man hate to see a G down !
Old May 4, 2015 | 12:59 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Jumping timing teeth at 130K seems a bit unexpected. I suppose if the car was abused this would happen. Great this repair is covered under warranty.
G37xhibeet
Nov 15, 2016 09:29 AM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
JoshB
Oct 15, 2015 03:08 PM
bikerjosh
Aug 19, 2015 11:26 PM
