Car WONT START! help!
Old Feb 16, 2015 | 04:54 PM
Gurp925's Avatar
Gurp925
Hi guys, so this morning when i go to start my car its completely cold actually was taking it for a oil change, it made wouldn't start it starts to crank and just makes a grinding noise. When inside the car its shaking when trying to start it, it kind of sounds like the timing chain i dont know. Should i take a video if so let me know should it be of the engine or inside the car, because i dont want to keep trying to start it.
Thanks boys
Old Feb 16, 2015 | 06:01 PM
Cr0tchf4i's Avatar
Cr0tchf4i
Hard to tell with those details. How cold was it? Did your gas freeze? Do you have any stabilizer in it?
It needs 3 things to start- Fuel, Air and Spark. Which one isn't it getting?
Old Feb 17, 2015 | 04:56 AM
telcoman's Avatar
telcoman
Originally Posted by Gurp925
.... Should i take a video ......
No!
Instead of a video why not try calling AAA for a jump start?
It was 2 above zero here in NJ yesterday morning and if you don't have a fully charged battery your vehicle will not start.
Did you try measuring the voltage across the battery when trying to start?
You can test individual cells with a battery Hydrometer
If the cells are not accepting a full charge replace the battery
Telcoman
Old Feb 17, 2015 | 06:09 AM
Call your mechanic or your dealership.
Old Feb 17, 2015 | 03:07 PM
Gurp925's Avatar
Gurp925
Sorry for not updating the thread i already got the car towed to a shop at the moment i refuse to take it to the dealer for fear of being ripped off, but so far i have replaced the battery problem still persists. It sounds as if the car is being starved of fuel, i did get it to turn on it sounded like it was running off 4 cylinders and managed to get a code not a real code imo it was engine misfire special code. So i'm looking at the fuel pump and maybe the relay any input?
Old Feb 17, 2015 | 03:46 PM
Which engine misfire code? If it's P0300 check oil pressure and pray it's normal.
Old Feb 17, 2015 | 05:00 PM
Gurp925's Avatar
Gurp925
So i'm off to go see what my mechanic says ill check on the code, but over the phone he said a mouse chewed up some wires.... ill get back to you guys with details lol.
Old Feb 17, 2015 | 05:03 PM
telcoman's Avatar
telcoman
...... i already got the car towed to a shop at the moment i refuse to take it to the dealer for fear of being ripped off,
Are you paranoid?
...... but so far i have replaced the battery problem still persists. It sounds as if the car is being starved of fuel, i did get it to turn on it sounded like it was running off 4 cylinders and managed to get a code not a real code imo it was engine misfire special code. So i'm looking at the fuel pump and maybe the relay any input?
Keep replacing parts as recommended by poorly trained individuals that masquerade as cheap mechanics.
When you are sick do you look for cheap doctors or seek out experts?
Good luck
Telcoman
Old Feb 17, 2015 | 05:15 PM
Gurp925's Avatar
Gurp925
It's not about seeking cheap doctors its about finding people who actually want to fix the problem without overcharging. I go to people who i know wont jerk me around, and you cant deny dealerships are known for ****ing people around. The dealership wants a $140 diag fee upfront, its not about spending money its about wasting it. The people taking care of my car are well trained and experienced they know what they are doing.
Old Feb 17, 2015 | 05:24 PM
2008G-Man's Avatar
2008G-Man
Hmmm ... just arbitrarily replaced the battery? Three (or four) basic steps to test battery.
  • Charge, check battery with load test for battery health
  • Check charging system voltage
  • Check for parasitic load
  • Check cells with hydrometer if not a maintenance free battery
Just did all these on my M and takes about 5 minutes max (after the charge). Hopefully they will put your old battery back in and not charge you for that. IMHO you need a different mechanic.
Old Feb 17, 2015 | 06:50 PM
Gurp925's Avatar
Gurp925
Nope I tested the battery one of the cells was dead measuring at 8v this is before my mechanic even looked at it. I appreciate the input but I did my diligence before spending the money. Found the problem by the way the mouse chewed through fuel injector wiring harness. Got some new wiring and boom she's up and running. Thanks boys.
Old Feb 17, 2015 | 07:03 PM
2008G-Man's Avatar
2008G-Man
Glad you got it fixed, I think this is a first for the forum .... mouse damage.
Old Feb 17, 2015 | 07:54 PM
Gurp925's Avatar
Gurp925
Mighty mouse drumming up business for local mechanics
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
G37xhibeet
Nov 15, 2016 09:29 AM
JoshB
Oct 15, 2015 03:08 PM
350zrunnin12s
Aug 9, 2015 09:55 PM
Corvalis
Aug 6, 2015 04:36 PM
