Slow Throttle Response
Old May 30, 2014 | 11:14 AM
Jack10525's Avatar
Jack10525
Is there anything I can do to improve throttle response without tuning?
Old May 30, 2014 | 11:35 AM
Tachyon's Avatar
Tachyon
Clean your throttle bodies, helps ALOT
https://www.myg37.com/forums/d-i-y-i...le-bodies.html
Old May 30, 2014 | 11:50 AM
canucklehead's Avatar
canucklehead
try an ECU reset. might help. search for the DIY on here, easy to do.
dholmblad's Avatar
dholmblad
MT or AT?
Old Jul 2, 2014 | 08:44 PM
Jack10525's Avatar
Jack10525
Auto trans....
Old Jul 2, 2014 | 09:34 PM
perez519's Avatar
perez519
Get standard light weight pulley from stillen. I have 6MT and I notice big difference but I'm also tuned. It should help on AT a little bit. Also get grounding kits that should help a bit.
Old Jul 2, 2014 | 11:51 PM
RexHavoc's Avatar
RexHavoc
I cleaned the throttle bodies and added a grounding kit and it changed things dramatically
Old Jul 3, 2014 | 03:31 PM
HoldmyMouse's Avatar
HoldmyMouse
https://www.myg37.com/forums/engine-...on-suit-5.html
Lol
Old Jul 4, 2014 | 11:57 AM
guy from norcal's Avatar
guy from norcal
+1 on the grounding kit. made a very noticeable differance in shifting.
I also got a hypertech tuner from a member on here after the grounding kit which helped with throttle response also. I only have cataback exhaust and drop in afe filters.
Old Jul 7, 2014 | 10:42 AM
CoolBreeze's Avatar
CoolBreeze
OP, have you had the ITB12-027 7AT fix yet? Scope out the forum TSB section.
Before I had the upgrade, my ride was a dog off of the line – severe throttle lag and it had slow response when I punched it.
Since, it is like driving another car.
Old Jul 7, 2014 | 11:50 AM
Mark1281's Avatar
Mark1281
I just got my car back from routine maintenance and they did a ECM update and reset my TCM. It drives like a new car.... much better than the Q50 they gave for me to drive.
Old Aug 5, 2014 | 01:47 PM
Jack10525's Avatar
Jack10525
Did the ground wire and throttle body cleaning. No improvement what so ever. Got an appointment with the stealer in a few days. Lets see how bad I get @ss raped!!!
misc
29
May 24, 2023 03:57 PM
linvbro
Aug 22, 2016 01:25 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 29, 2015 10:58 AM
dedmanchan
Sep 24, 2015 11:25 PM
