Limp Mode, Code P0021. Dealership wants $2650
Old Feb 18, 2014 | 10:39 AM
Byron Sexton's Avatar
Byron Sexton
Why should you be responsible for the fix If you had your oil changed at the Infiniti Dealership, and no one told you anything about it?
Seems to me that The dealership should be responsible and they should fix it on their dime.
Is the oil level at the recommended height??????
If you didn't do anything to the car between your last oil change and now It has to be something that they did...only makes sense because they were the ones that touched your car Last.
Old Feb 18, 2014 | 10:45 AM
SPDCRZ's Avatar
SPDCRZ
The dealership will usually screw you on labor, hope you take this in to account before going to them to replace the part.
Old Feb 18, 2014 | 04:04 PM
Synolimit's Avatar
Synolimit
I wouldn't let a dealer open my car door! Oil changes are done by kids off the street. You'll only get a competent tech for serious things.
Old Feb 20, 2014 | 01:41 PM
Phimphasone's Avatar
Phimphasone
I had this same issues once, my car wouldn't go over 2500 RPM's... come time find out it was just dirty air intake filters. try removing them and start your car and see if it rev's past 2500 if it does then bam! replace them and boom fixed! if not then.... GOODLUCK!
Old Feb 21, 2014 | 01:01 PM
GTLAW's Avatar
GTLAW
Dude!!!! don't pay anything this is an TSB for sure! They are trying to rip you off.
Contact Infiniti tell them what's going on, go to another dealer! this is not your fault!
Don't pay a dime to have this fixed.
Old Feb 21, 2014 | 01:12 PM
OP, you may want to check out this thread.
https://www.myg37.com/forums/engine-...and-p0524.html
Old Feb 22, 2014 | 04:23 PM
mudpaw's Avatar
mudpaw
I've been chasing the same issue. Dealer wanted $400.00 for the IVT solenoid. I found it here for 1/2 the price.
2008 G37 Coupe: OEM Body (Front, Roof, & Floor) (HOOD PANEL,HINGE & FITTI) Replacement Parts
Since I have a mechanical background I replaced it myself. Unfortunately my problem persists. My next step will be to remove the cam covers and inspect the gaskets.
Old Feb 23, 2014 | 11:21 AM
TVPostSound's Avatar
TVPostSound
When will people realize that a TSB is not a recall.
Its a service bulletin hep other tech diagnose an issue.
The car is no longer under warranty.
Old Feb 23, 2014 | 11:52 AM
When they take the car in at 78K miles and get laughed at when they say they want it fixed for free? I can let you know later this week.
And for the record I didn't find any such TSB regarding this issue. Did I just miss it?
Old Feb 23, 2014 | 01:45 PM
TVPostSound
I was told by an Infiniti tech, as a side note, that if I ever have low oil pressure, to mention the timing cover gasket TSB.
There was a TSB, it was written s
o techs wont go blindly searching.
However, I have a 120,000 8 year Elite Warranty.
Old Feb 23, 2014 | 06:37 PM
NJ Torque's Avatar
NJ Torque
I dont know of any regarding this...
Old Jul 28, 2015 | 01:04 PM
acl128's Avatar
acl128
2010 G37s Vert, 25,000 miles had same problem. Car went into limp mode and was not able to go over 2000 rpms. Error codes P0300 and P0011. Dealership first determined faulty valve timing solenoid but did not fix problem. Then determined camshaft timing sprocket needed to be replaced as the valve timing "chatter"/pick up wheel goes negative due to low oil. Covered under 6 year power train warranty. However, took about two weeks due to fight between power train and extended warranty companies. Extended warranty company said wouldn't cover due to Power Train warranty, and Power Train warranty argued that symptom is due to poor maintenance as they only had one dealership oil change at 15,000 miles. If you do oil changes elsewhere, keep your records.
Old Jul 28, 2015 | 03:23 PM
astat4's Avatar
astat4
I'm experiencing something similar. My car is in limp mode and I actually accidently ran it with low oil pressure. It random died on me driving.. Nissan told me my engine was done cause it skipped it timing (it did). Warranty didn't cover it. So I retimed the engine my self. It turns on now and runs with the cam sensor disconnected . But it's in limp mode at 3.7 rpm. So this past weekend I opened it up again to retime it thinking I accidently you know did it wrong. Well my problem still persists of limp mode. All crank and cam sensors are new. I get a cam sensor code (p0340).
I've came down to my phaser (intake cam gear) is frozen. 2 master techs told me this would be my problem. The cam gear is stuck so it can't retard or advance timing.
My .02
Old Sep 19, 2017 | 09:40 AM
  #29
newmarket's Avatar
newmarket
With a help of a few forums I will share my experience..
My oil was low and very surprised because usually Royal Purple doesn't burn off that much. But it did probably at least 1 quart maybe 2.. don't know how long I was driving like that but about a few days after I topped it off I got the P0021 code.. After extensive research through forums and on Youtube they said try an oil change first.. I did and the code was still there with same problem.. I reset my ECU by disconnecting the battery and guess what... everything was back to normal.. from some guy on Youtube he said that the solenoid or something expands when the oil pressure is low.. so what I believe happened is it went back to normal after I reset the ECU and with normal oil pressure..
Resetting the ECU was key..
Very happy now
Old Oct 5, 2017 | 10:34 PM
  #30
blkceaser's Avatar
blkceaser
Bro this may sound crazy but test your battery. I literally just had this happen to me yesterday. My car was barely moving in reverse and drive but in park, the engine would rev. I changed the battery( I don’t know what made me do that) and everything worked perfectly again
