Car shakes @ 1500 RPM
Old Mar 18, 2013 | 03:22 PM
anndy811's Avatar
anndy811
Hi All,
I'm a long time Infiniti owner. I had a 05 G35 coupe 6MT, then 07 G35x. Last Sunday, I traded the X sedan for a Used 2011 G37S Sedan 6mt.
I noticed something unusual with my RPM yesterday. When I rev my engine the needle would pause @ 1500rpm for a second and my engine would shake a little then back to the idle position. No mechanical issue with the vehicle, it drives fine. I contacted my nearest dealership and scheduled a time to diagnosis the issue. I just want to get everyone's opinion for what I should expect. I tried ECU reset, but that didnt solve the problem. Could it be a dirt TB? Please let me know your thoughts so I can bring to the Tech's attention.
ps - car is stock
Andy
Old Mar 18, 2013 | 03:33 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Cleaning the throttle bodies would be a starting point.
Unless your dealer is really nice, they'll likely charge you for this service as it is a maintenance item... Good luck.
Old Mar 18, 2013 | 06:05 PM
GeezerB's Avatar
GeezerB
I believe this is perfectly normal behavior. The rev limiter kicks in when not in gear.
Old Mar 18, 2013 | 06:33 PM
sniper27's Avatar
sniper27
Not at 1500 rpm. Mine has issues like the OP on occasions as well. When not in gear and I rev, it will go up pass 2k. But as it drops down, it will hover around 1500 for a few seconds, then drops back down to about 500. I'm sure my TB needs a cleaning.
Old Mar 18, 2013 | 10:58 PM
anndy811's Avatar
anndy811
thanks... thats what i suspect. The car sat at the dealership for 4 months before i took ownership of it. probably build up inside TB.
Old Mar 18, 2013 | 11:35 PM
ErikM's Avatar
ErikM
Try Techron in a few tanks of gas.. best fuel system cleaner out there
Old Mar 19, 2013 | 08:44 AM
SwissCheeseHead's Avatar
SwissCheeseHead
Originally Posted by ErikM
Try Redline SI-1 in a few tanks of gas.. best fuel system cleaner out there
Fixed it for ya
aliiin
Apr 27, 2018 10:37 PM
regimelife
Aug 18, 2015 04:46 PM
mauiwowie
Aug 16, 2015 06:01 PM
Jeebus
Aug 1, 2015 10:26 PM
