Engine warming up
Old Jan 23, 2013 | 09:05 PM
Danielrodriguez's Avatar
Danielrodriguez
Engine warming up
I have a g37s coupe my brothef a 335i coupe. When we both turn on our cars, my temperature isat normal in less than 3 minutes. Any other car i have driven takes a lot longer. Is there something wrong with my rngine? I dont want to floor it if my engine marks the temp as normal but in reality it may not
Old Jan 23, 2013 | 09:23 PM
prescott3656's Avatar
prescott3656
Are you just looking at the analog dash gauge? Mine shows "normal" when my oil temp is actually only about 95 degrees, so i don't rely on that. I won't go anywhere near WOT until it is at least 160-180 degrees and that can take 15-20 mins of driving sometimes.
Old Jan 23, 2013 | 11:45 PM
Weiboy718's Avatar
Weiboy718
Of course! That's your water/coolant temperature. Your car does not have a oil temp gauge.
What up buddy, long time! Same for you, the analog is your water temp.
Old Jan 24, 2013 | 10:26 AM
kcg37's Avatar
kcg37
Me thinks Direct Inj. motors like the N54 (in the 335i) take longer to warm up. Our EOS (w/ DI 2.0T is the same way.
Old Jan 24, 2013 | 01:08 PM
Abramite's Avatar
Abramite
I would say displacement might have a part in this
Old Apr 13, 2013 | 01:03 AM
DONTTASEMEBRO's Avatar
DONTTASEMEBRO
I was told it's that piece of insulation glued to your engine hood, so the engine could get to optimal temperature faster even in cold conditions...
Old Apr 16, 2013 | 04:54 PM
GoCougs's Avatar
GoCougs
Mine rises real quick too. Could be the volume of coolant is small but my hunch is the G37 temp "gauge" is just the inverse of an idiot light in gauge form - after a certain temp above nominal the gauge registers normal.
Old Apr 16, 2013 | 05:16 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Maybe someone wants to volunteer hooking up torque and logging engine parameters from a full cold start until it hits operating temp (195*F?).
In the winter, (20-30F), I do get warm temp relatively quickly (5-10 min) of driving.
I'd do it myself, but I don't drive every day.
Old Apr 20, 2013 | 12:24 AM
ukmastermind's Avatar
ukmastermind
You're right, the engine warms up to 145-155 degrees within a few mins...
It would take my 370z 2 extra mins to get to that temp
P.S. I use a Scan Gauge to monitor temps
Old Apr 20, 2013 | 05:19 AM
keraxis's Avatar
keraxis
It was designed that way
Our motor is designed to heat up quickly so that it can heat up the catylatic converter and not put out as much polution during warm up. Listen to the sound of the motor when you first start it up. Seems loud for a modern car doesnt it... Its supposed to and nothing is wrong with it.
Junchao Sun
25
Oct 1, 2015 12:41 PM
m3clubracer
Sep 28, 2015 03:45 PM
mikysee
Sep 28, 2015 11:18 AM
dedmanchan
Sep 24, 2015 11:25 PM
