New GTR Tranny in my G37
Old Nov 24, 2012 | 08:28 AM
G37Sam's Avatar
G37Sam
I don't think there's a difference in terms of hardware, maybe just the transmission tune?
Old Nov 24, 2012 | 08:34 AM
ashmostro's Avatar
ashmostro
I've heard its just electronics, but that it hasn't been unlocked yet. Its not line pressure maps. Trying to figure out if an ecm swap is required because the z really does respond much quicker to manual shift commands.
Old Nov 24, 2012 | 02:59 PM
Dark Sarcasm's Avatar
Dark Sarcasm
It shifts faster because it has Rev Matching on up shifts. When you hit the paddle the rpm's don't drop as it changes gears. It's like heel toe shifting for upshifts. All in the programming of the TCM or ECU if you ask me.
Old Nov 24, 2012 | 03:09 PM
G37Sam's Avatar
G37Sam
How can a car rev match on up shifts? If you shift out of 1st at 7k rpm, that's around 40 mph. Going into 2nd at 7k rpm (since as you said, rpm's don't drop) would mean the car would have to jump to 65 mph instantaneously to match the engine speed. If we assume shift time is 0.2 seconds, then we're looking at 6G's worth of acceleration between gear shifts
Old Nov 24, 2012 | 04:40 PM
ashmostro's Avatar
ashmostro
Yeah, that didn't make sense to me either.
To clarify, I'm talking about how fast the car interprets a manual shift command. The Z does it at least three times earlier, if I were to venture a guess.
Old Nov 24, 2012 | 07:36 PM
B L U E S L A T E's Avatar
B L U E S L A T E
Look at his user name. lol
B L U E S L A T E
Oh man... Trolling at its best.
Old Nov 24, 2012 | 09:25 PM
Dark Sarcasm
No, I'm serious this time, lol. Nissan has a name for the trans program that helps increase up shifts. I think it's called DRM. I will double check.
Old Nov 24, 2012 | 09:39 PM
Dark Sarcasm
Okay, I researched the370z.com and found out its called DRM, Downshift Rev Matching, which blips the throttle when downshifting not upshifting, like I thought.
At any rate, the trans in a Z is the same as the trans in the G, it's just programmed differently.
Old Nov 24, 2012 | 09:59 PM
LexiG37's Avatar
LexiG37
So...., you brought nothing to the table. Good try though.
Old Nov 24, 2012 | 10:17 PM
ashmostro's Avatar
ashmostro
I'm inclined to wait for the informed opinion of someone who knows the difference between down and up shifts...
Old Nov 24, 2012 | 11:09 PM
LexiG37's Avatar
LexiG37
Ha ha!!! So true.
Old Nov 25, 2012 | 12:50 AM
dal1307's Avatar
dal1307
\ The 370Z shifts as fast as the GTR
Really?
Old Nov 25, 2012 | 10:59 AM
  #29
Dark Sarcasm
Originally Posted by dal1307
Really?
Haha, damn, you guys are brutal. And yes, my 370Z performed upshifts just as quickly as a GTR, of course the differences could be in milliseconds. My 370z in manual mode would light up the tires in 2nd gear, and bark the tires going into 3rd gear under full throttle.
Just trying to help the OP see that the G trans has the ability to perform to his needs.
Old Nov 25, 2012 | 06:11 PM
  #30
ashmostro's Avatar
ashmostro
No worries. We're just trying to keep things factual
