2008 G37s Engine noise when in gears at idle.
Old Feb 27, 2012 | 05:18 PM
ThaqAtaq313's Avatar
ThaqAtaq313
Unhappy 2008 G37s Engine noise when in gears at idle.
Hello Everyone,
I have been having this oddly strange noise come from the engine area, and the noise seems to be relevant mostly when in gears at idle....sounds like a disks almost rubbing against each other. This chit as been going for 3 months and after replacing the short block and a purged cylinder the noise is still there.
As anyone else been experiencing this as well?
Thank you for your response in advance.
Old Mar 11, 2012 | 08:35 PM
brainpa's Avatar
brainpa
You changed the shortblock????
Explain please
Old Mar 11, 2012 | 10:45 PM
Polar_g37s's Avatar
Polar_g37s
I'am assuming he had a bad block and changed it out. But anyways that's just your tranny making noise don't leave it in gear when stopped preferably.
Old Mar 11, 2012 | 11:21 PM
ThaqAtaq313
Explain please
So, I took in my car in December of 2010 - there was this annoying noise almost a racketing noise that is relevant when in gear (reverse or drive).
No, they changed the block because of the noise. They turned off a cylinder and the noise would go away - they also reset the ecu, used ether oil, changed the cylinder valve - whatever else to save their asses. They are not done with me though - I have a great lemon law case on them. Also, my car is a automatic.
Old Mar 12, 2012 | 11:28 PM
Q8y_drifter's Avatar
Q8y_drifter
sound/video clip of noise?
Old Mar 18, 2012 | 08:39 PM
ThaqAtaq313
I tried to record, but to no avail.
UPDATE: Just received a call from Nissan-USA and they are buying back my car per CA Lemon Law. This was once they pushed me to the edge and wrote a inquiry with the BBB Autoline.
Slateg37
Sep 16, 2015 05:52 PM
hamwich
Aug 17, 2015 07:51 PM
GW330
Aug 12, 2015 12:19 AM
HB4LTHR
Aug 9, 2015 11:12 AM
reigle9
Aug 6, 2015 02:45 PM
