Who has a Stillen G37 Supercharger? Numbers, pics, vids!
Old Feb 1, 2016 | 12:56 PM
  #676
stevo4756's Avatar
stevo4756
Originally Posted by PongSanity
I may have to reread this thread incase I've missed it. Has anyone built their block to max out the power of the stillen supercharger? On a stock block its around 440-460. Has anyone seen where these kits peaked at? Any difference with e85? ECUTEK?
Not entirely sure, but after reading about 40 pages it looks like most ppl that try to push the stillen kit end up blowing their motors. Better go turbo if your trying to push tons of boost.
I can't decide if I want to chance blowing up my healthy 08 motor that has 90k miles?
Anyone have this kit on a higher mileage g for an extended period of time?
Old Feb 26, 2016 | 09:56 PM
  #677
cougarxcguy's Avatar
cougarxcguy
My car is going under the knife again. 1000 cc injectors,340 fuel pump, si upgrade for the v3 through vortech, a 2.95 in pully, and a 50 mm tial qr bov. Will let yall know the results, should bring me up to 15psi ish
Old Feb 26, 2016 | 09:57 PM
  #678
cougarxcguy
Stevo i have 86,000 on my car and no issues, read my earlier posts
Old Feb 27, 2016 | 02:13 AM
  #679
milkcow500's Avatar
milkcow500
Any plans on a fuel return kit or or moving the MAFs? I've seen people go this route and blow their motors. It's most likely due to fueling issues/IATs. If you aren't switching out for EcuTek, I'd be very careful.
Old Feb 29, 2016 | 11:21 AM
  #680
Team_STILLEN's Avatar
Team_STILLEN
Built motor?
Old Feb 29, 2016 | 05:29 PM
  #681
ANMVQ's Avatar
ANMVQ
Hope he does or
Old Mar 1, 2016 | 09:32 AM
  #682
milkcow500's Avatar
milkcow500
I'll be doing the same on stock block. The real issue is this:
Old Mar 3, 2016 | 11:37 AM
  #683
cougarxcguy
Stock motor, from what i have read and heard to rotating assy is good unless you break 400 ft lbs tq, i am now at 331 so i don't think i will get over 400 ft lbs with this. I have uprev mafs and the tuner said that there would be plenty of voltage. I don't have anyone even remotely close to me that does ecutek. If i pop the motor im going to throw in a z1 proformance short block with a 9:1 ratio
Old Mar 3, 2016 | 11:40 AM
  #684
milkcow500's Avatar
milkcow500
Get sebastian from specialty z to tune it remotely. SI upgrade + 9psi pulley will get you around 13psi btw.
Old Mar 5, 2016 | 12:51 PM
  #685
lownslow's Avatar
lownslow
My only question is stillen Sc G37 vs FBO 335i Who wins ????
Old Mar 6, 2016 | 09:30 AM
  #686
RadioFlyer's Avatar
RadioFlyer
SC G37. Not by much, but I had him at the upper half of each gear. I'd start making ground over 5-5.5K. Shortly after, he would shift, and I would keep pulling to a higher redline. It seemed pretty close power-wise (I'd bet our dyno sheets are pretty close), but the gearing and higher redline helped move the g37 down the road faster.
BTW, this was on the front straight at Summit Point Main. Middle of 4th to the top of 5th gears in the G - speeds of 90-140 mph. The gearing could have played out differently in different gears or speeds, so YMMV.
Old Mar 6, 2016 | 02:05 PM
  #687
lownslow's Avatar
lownslow
I have 4.08s and all the na bolt ons Was planning on doing cams throttle bodies , lower manifold and CF driveshaft, but now I'm leaning towards the SC Initially i will leave the 4.08s and see how they pair up with the sc. A couple of my friends have 335s and we drag at our local drag strip ETown The season is coming up I wanna make sure I'm not wasting money
Old Mar 6, 2016 | 11:49 PM
  #688
RadioFlyer's Avatar
RadioFlyer
If you're thinking about building for quarter mile, you want all the power you can get. These cars are terrible to launch, so I'd bet a 335 would lunch on you and you would have to make it up on the after the 1/8th. I haven't drag raced my car yet, but I suspect high teens in the mph. Something in the neighborhood of 117-119mph. Do you know what your friends' BMWs usually run? My guess is that a SC'd G would run in the high 12's, but with a high mph because of the launch. Also, you'll probably have to shift into 5th just before the line, so that would hurt your time as well.
Old Mar 7, 2016 | 08:57 AM
  #689
lownslow's Avatar
lownslow
I think one of them traps like 112ish Damn I was hoping i could be in the low 12s There's a guy on here with an NA auto running 12.7
Old Mar 7, 2016 | 09:07 AM
  #690
milkcow500's Avatar
milkcow500
There's a Stillen SC Q50 hitting 12.0 @ 11psi.
