High idle and rev hang after cleaning TB
Old Nov 15, 2011 | 09:56 PM
Itchytoe's Avatar
Itchytoe
It's good that you didn't eat $60 worth of cookies. You'd have one hell of a tummy ache if you did.
Old Apr 15, 2013 | 12:20 PM
G35S_IPL's Avatar
G35S_IPL
Hate to reopen this thread - but at least this will help others in the same situation.
Do the two steps before this COLD Motor
1. 2 (Sec) On
2. 10 (Sec) off
3. 2 (Sec) On
4. 10 (Sec) off
1. 2 (Sec) On
2. 10 (Sec) off
HOT PIPING HOT MOTOR ( not 10/15minute drive..... I beat it up for 20-30 minutes ) then did the following
1) turn ignition to ON
2) wait 3 seconds
3) pump gas pedal 5 times (dont wait between each one, just pump the pedal 5 times)
4) wait 7 seconds (some people say they have better luck if they wait a little longer, like 7-10 seconds)
5) Press down gas pedal and wait. this is the part where the check eng light will come on after about 10 seconds
For this I have an issue - What did was START the car the within 3 seconds SES light of it being solid -
To summarize the last bit -
After the wait of 7-8 seconds ( Step 4) - press and hold throttle pedal (Step 5)- flashing SES - then SES will go solid - within three seconds of it going solid start the car.
This worked perfectly for my 2007 G35s.
Old Oct 5, 2016 | 05:36 PM
derfranzer's Avatar
derfranzer
Angry
After cleaning the TB, I can't get my G37 to hold the idle relearn. Tried several times including at the ECM. When the idle is about 650, service engine soon light is off. When the idle is 950, the service engine light is on (P0171 and P0174). Any suggestions? I think I've taught the car its idle over 10 times. Are there remedial classes I need to take my car?
Old Apr 7, 2017 | 08:26 PM
derfranzer's Avatar
derfranzer
Chasing Idle Relearn issues
The high idle and lean code have been fixed by replacing the fuel pump.
Old Apr 8, 2017 | 02:01 PM
Stachuu's Avatar
Stachuu
I disconnect battery before I clean TB's every summer, never had any issues.
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
r0cketm0nkey
17
Nov 23, 2015 03:34 AM
Rayramg37
Nov 18, 2015 09:06 AM
StAtiXz6
Intake and Exhaust
Sep 17, 2015 03:10 PM
ZachThomas
Sep 3, 2015 01:40 PM
