Looks like the auto tranny isn't engaging properly, similar to a slipping clutch. Check the tranny fluid and if that isn't it you'll probably need to see a mechanic.
That is a pick of your dash, not running.
Slip light is picture of the car with the s shaped lines in the 1st vídeo.
Start engine & turn vdc off.
Check your owners manual.
today i went to mechanic and he check the engine and sensors & he tell me maybe the throttle body need reprogram.
there is any way to reset the throttle body?
Thanks guys
You can't reset the throttle bodies. We do have a pair of them, but we don't use them really. The VVEL system does all of that for us. The throttle bodies just stay opened unless the VVEL system messes up if I'm not mistaken.
