Oil Change Reset on Dot Matrix Screen
Old Jun 10, 2011 | 08:53 PM
jmeyer99's Avatar
jmeyer99
I have not been able to turn off the oil change indicator on the dot matrix screen between the odometer and the speeddometer. I have gone through the maintence/oil/rest option from the owner's manual without success. What's the secret to turning off this feature?
Best,
James
Old Jun 10, 2011 | 09:00 PM
rks's Avatar
rks
Best,
James
good question. I fu%$ed with it until it reset accidently.
Old Jun 13, 2011 | 07:53 AM
KLB's Avatar
KLB
Turn it off? Did you try setting it to 0 miles?
Old Jun 13, 2011 | 09:03 PM
gsm026's Avatar
gsm026
Yeah, it's a bit of a pain, but page through the display to maintenance, select, go to Oil Change and select that, then select reset, should highlight the miles driven number. Then hold the reset button. It shows you which ones to use the uppper button for and which one to use the lower button for with little square and circle pictures. Then repeat for Oil Filter.
It's been a couple of months, but if I remember right, you have to be stopped in neutral or park with the car running.
Greg
Old Nov 20, 2011 | 10:05 AM
mickylong's Avatar
mickylong
Dot Matrix Maintenance screen won't reset
I'm having the same problem with my '08 coupe. The reset procedure outlined here doesn't work. When I try to use the upper button which is labeled "enter" vs. lower button labeling "next" it won't reset or allow me to change the mile indicator for service. Happens on both oil filter and Other indicator.
Car is in Park with brake on, engine running. What else should I try?
Old Dec 24, 2011 | 04:04 PM
Greg S's Avatar
Greg S
I'm having the same issue with my 10 sedan. Were you able to figure this out?
Victory
Sep 28, 2015 10:49 PM
ryang37x
Sep 22, 2015 05:33 AM
sharmelan
17
Sep 14, 2015 03:18 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
harlemcat45
Sep 9, 2015 09:35 AM
