Dirty Rear Differential Fluid?
Old Oct 19, 2012 | 07:00 PM
  #31
Originally Posted by 00Max00
Changes were they never looked at it.
Should I have used the sarcasm smiley?
Of course they didn't look at it. You can't look at it unless you remove the plug from the differential and drain it out. So any "inspection" that tells an owner that they need to change it becasue it's "dirty" or 'low" is BS. If they were being honest instead of trying to scare owners into getting service they'd be truthful and say that they recommend changing it becasue it has been in service for xxx miles rather than to tell them lies.
Old Oct 20, 2012 | 12:14 AM
  #32
dkmura's Avatar
dkmura
20 Year Member
Originally Posted by soundmike
The fluid that came out of my differential was rather dirty, stank pretty bad, too. It had about 30k on it.
The tranny fluid is close to the color it would be when new. The smell is from the sulfuric pressure additive in the lubricant (normal, not worn). This picture clearly shows the fill hole (located to the right and above the drain). Both use allen head bolts.
Old Oct 20, 2012 | 10:30 AM
  #33
00Max00's Avatar
00Max00
Yes, they could if they wanted to. The filler hole is usually where inspection to be done by sticking a finger into it. The normal fluid level should be at the bottom of the filler hole, if your finger could not touch oil, it was low.
Old Oct 21, 2012 | 08:54 PM
  #34
TinsleyC's Avatar
TinsleyC
The sales tactic' that i was given was that the 09's came with two different fluids, one was meant to be a lifetime fluid, the other wasn't, and there was no real way to tell which I had. So, they recommend changing it to be safe. Since I'm a fan of changing fluids I agreed with about 28k on the car. I'll likely do it again at 60 to 80k miles.
Old Oct 22, 2012 | 08:58 AM
  #35
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I just got a call form the dealership letting me know that mine needs to be changed soon and I asked them how much they wanted to charge me and they said $240 for both front and rear.
Old Oct 22, 2012 | 11:37 AM
  #36
hadokenuh's Avatar
hadokenuh
30K is a good time to replace it anyway, per the manual. $80 is actually a great price. My local dealership usually charges $100-120.
Old Nov 11, 2013 | 02:21 PM
  #37
TheLocNar's Avatar
TheLocNar
Bumping this old thread. I'm a little overdue with my x sedan. Almost 34,000 miles.
What weight does the X need? Lost my owners manual, of course.
Motul has 80w90 and Redline has 75w90.
4QT total should be plenty for both front and rear?
Old Nov 13, 2013 | 04:53 PM
  #38
Glenn2008's Avatar
Glenn2008
The dealer gets $130.00 to change out the diff. and $170.00 to change out the brake fluid. I bought the Motive powerbleeder with adaptor, 2 qts of 75W90 Mobil 1 synthetic and 2 quarts of super blue. Total outlay was @ $125.00. I'm going to do the work this weekend.
Old Nov 13, 2013 | 05:08 PM
  #39
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I just got mine done and they charged me $80 for the front and $80 for the rear.
Old Nov 14, 2013 | 12:22 AM
  #40
socketz67's Avatar
socketz67
Community Builder
I have always changed the Diff and Trannie Fluid at 30K intervals. The dealer here said it's not necessary to change the diff fluid that often since they have been using synthetic fluid for many years now.
Old Nov 14, 2013 | 09:18 PM
  #41
TinsleyC's Avatar
TinsleyC
You can get a new manual here:
https://owners.infinitiusa.com/iowne...nualsAndGuides
Old Jul 26, 2017 | 11:55 PM
  #42
mjsheen's Avatar
mjsheen
Magnetic drain!
You gotta do magnetic drain to get those metal wear paticles out!
91dx
Aug 1, 2016 10:46 PM
G37S-K52
Southern California
Sep 11, 2015 01:10 AM
Badgerman
Aug 19, 2015 02:26 PM
zero260
Aug 12, 2015 10:02 AM
