RPM dips low at idle
Old Nov 12, 2014 | 10:39 PM
  #61
sprix's Avatar
sprix
I'll chime in again and say that I have not had any issues since doing the TB cleaning on my coupe in May. Smooth sailing.
Old Nov 17, 2014 | 05:01 PM
  #62
b3nmo's Avatar
b3nmo
Exceptional Service?
So I had the dealer look at the throttle bodies. The tech told me he sprayed some throttle body cleaner into them. Car seemed to be more responsive and the idle was definitely better - around 6-700 RPMs. He said there was nothing in their database to indicate a problem with the idle or any problem with the throttle bodies. He also mentioned I shouldn't put too much stock in forums.
Got about a mile away and at the first stop before the freeway - - car shuddered and dropped down to 400 RPMs. Guess I'm going to have to do this myself.
Old Jun 10, 2015 | 11:38 PM
  #63
g37vegas's Avatar
g37vegas
Sorry everyone for opening up an old post... Got a 2011 IPL this last weekend and have the same issue.. It definitely drops more with the AC on than when its off.. Was wondering if the dealer flashes was something you had to pay for? Probably I would guess.. Will try the TB cleaning too
Old Jun 14, 2015 | 03:37 AM
  #64
xxg00w0's Avatar
xxg00w0
Clean my TB, Problem solved.
Old Mar 19, 2018 | 12:24 PM
  #65
Cmedina30's Avatar
Cmedina30
Originally Posted by htownboy
Clean TB and get a pressurized fuel injection system cleaning. I do this every 15,000 miles and results are noticeable. More power, smooth idle, gas mileage boost. As I reach the next 25,000 the rough low idle etc. begins to return. Been doing this for years and it works well.
​​​​​​ive just bought a 08 infiniti g37S 6mt it just started to bogg down at stop lights and I just did what you suggested I cleaned the TB's and it totally fixed the problem easy cheap fix! Veeeeery happy with this simple fix! Thank you for the info!
Old Aug 23, 2019 | 10:07 AM
  #66
Jsbach1685's Avatar
Jsbach1685
Originally Posted by tommyblackwell
My 2008 G37 has been doing that since 27k and i finally figured out the issue. I had to have my idle bypass valve cleaned and the issue stopped for me. its been about a month since its happened last. I have had it in the shop about 20 times and they could never fix it. I thought i would pass this along since it seems to become more of an issue.
When you say "idle bypass valve" would that be the Idle Air Control Valve? Can you take a pic and post it?
Old Aug 26, 2019 | 03:04 PM
  #67
Baadnewsburr's Avatar
Baadnewsburr
ummmm.....This guy made this one post over seven years ago and hasn't logged in since...not very likely that you'll get an answer, better idea is to start your own thread about your issue (with your own pictures) or bump a newer one
Old Aug 26, 2019 | 04:07 PM
  #68
Jsbach1685's Avatar
Jsbach1685
Lol... I had no idea it was that old. Thanks for the heads-up! :-)
projectpanda13
Jun 4, 2024 03:25 PM
shawnberry45
General Tech Questions
Mar 14, 2018 10:24 PM
ggggg37
May 19, 2014 02:04 AM
Sharkweek
Jan 3, 2013 02:55 PM
trcb777
Sep 5, 2011 02:39 PM
