G37 7speed transmission reprogram
Old Jan 13, 2011 | 12:52 PM
  #181
Almatti's Avatar
Almatti
Oh Yeah: When Reflashes are done, isn't the ECU RESET automatically by the dealer?? I will make sure that it is reset as a few have mentioned...
Old Jan 13, 2011 | 01:29 PM
  #182
sniper27's Avatar
sniper27
Originally Posted by Almatti
This is exciting results from so many.... I have an appointment for tomorrow. One member posted about that "empty" feeling when rounding corners, that was Gone... That's the feeling I get when stepping on the brake, then the gas, it has that "empty" - Lagging - hesitation feeling. Man, if that is corrected: WOW!
I'll post my results as soon as I can. These recent posts of your results, have "unchickened Me Out"....
keep us posted. I'm due for my 2nd oil change in a couple weeks. still debating on this.
Old Jan 13, 2011 | 02:06 PM
  #183
hollowplayer's Avatar
hollowplayer
i just got my oil change on Monday, and i didnt know until i read this thread. Shifting is definitely smoother, dealership updated it without my knowledge.
Old Jan 13, 2011 | 05:02 PM
  #184
hufington's Avatar
hufington
Bashi & hufington: Your Comments may have "Unchickened Me Out" of applying the Reflash to the ECU /TCM.... To confirm we are talking about the ITB10-075 TSB?
I still have not seen the TSB posted on this forum. Has anybody seen it or give a link where it can be downloaded? THX
That's the correct one. Don't worry. The service types in your VIN# and it comes up automatically.
Old Jan 14, 2011 | 09:50 AM
  #185
clutch5's Avatar
clutch5
This is interesting since it implies this particular dealer feels it will be an improvement for everyone.
On the ECU reset for the learned transmission parameters, can this only be done by the dealer, or is there a way for the owner to reset it via the in-car diagnostic menus?
Old Jan 14, 2011 | 09:56 AM
  #186
PascalT's Avatar
PascalT
I asked the dealer if it's available.. if it is I will be doing the update asap. As I paid more attention to the transmission this week I definitely noticed that under 40km/h (25-30mph) the transmission is really wonky and choppy in stop and go traffic.
will report here when it's done.
Old Jan 14, 2011 | 10:38 AM
  #187
1BadAssG's Avatar
1BadAssG
here you go
https://www.myg37.com/forums/d-i-y-i...isconnect.html
Old Jan 14, 2011 | 12:20 PM
  #188
clutch5's Avatar
clutch5
Thanks for the link bashirdur.
I'd have never guessed there would be a 100+ post thread covering the insanely cumbersome procedure. Seems it should be as simple as selecting a menu item, then selecting what all you want to clear, then confirming that you want to clear the settings by holding some button in for 5 seconds or something. I bet the engineers got a big kick out of creating this Rube Goldberg machine for performing an essentially harmless operation )
Old Jan 14, 2011 | 02:20 PM
  #189
MaluG37's Avatar
MaluG37
Went to the dealer today for the reflash and I got bad news. The consult III that they use to check the cars computer did not display a transmission part number and therefore this bulletin didn't apply to my car. The bulletin is for 2009-2011 G37 and 2011 G25 trans issues, so I figured my 2010 would apply. I found out later that the dealer had issues with there consult III and they are waiting for an update, so maybe when they get the update I can get the reflash. But I was so dissappointed that I couldn't get the reflash.
I was able to get my hands on a copy of the service bulletin and I'll post it as soon as I can scan it in.
Old Jan 14, 2011 | 03:19 PM
  #190
MaluG37's Avatar
MaluG37
ITB10-075 Service Bulletin
Everyone
Attached is a copy of the service bulletin for the 7AT issues. I haven't been able to get this update since the Transmission Part Number was not displayed on the Consult III when connected to my car as shown on page 3.
Old Jan 14, 2011 | 06:04 PM
  #191
Legz's Avatar
Legz
wow nice thanks for the hardcopy
Old Jan 15, 2011 | 09:43 AM
  #192
Almatti's Avatar
Almatti
sniper27, and other members, I had the Reflash done yesterday. I've only driven 7 or 8 miles from the dealerhip to home, but the following aare the immediate feelings of the chnage:
1. Seems to have a little smoother take off acceleration - more linear as some have described. Not sure yet if it lost a little something;
2. Definetely comes to a smoother coasting stop, which is a result of a different Shift point 3>2>1...
3. Definetely less abrubt shift in Manual mode 3>4>5 and 5<4<3.. I used to feel that 4<3 shift harder; more testing to be done in DS mode. Initially, seemed that the sporty shifting felt that it was affected....
4. Still has Lag !! I tested at 40 or so MPH, hit the brakes lightly, then on the gas again, LAG !! IMO, not any better than before the reflash;
5. I will report further after a good hard drive today...
Since I do feel the chnages on the driveability and the Service Advisor confirmed that the ECU / TCM was Reset, I don't think a reset is needed?? But after reading the link that Bashi sent, I may do the Reset anyway to clear the previous learning curve and drive 'er Hard for 10-20 miles.
Old Jan 15, 2011 | 10:51 AM
  #193
joker13's Avatar
joker13
just had this tsb done. dont get your hopes up. it didnt fix my problems...just kinda altered them a bit.
Old Jan 15, 2011 | 05:54 PM
  #194
Hellcat716's Avatar
Hellcat716
My tsb reset did not do any good. I did reset the ecu and now I am very happy. Very smooth in all gears when it shift's. No hard downshifts at all, acceleration is very good with very little hesitation if any. Hope it will last.
Old Jan 16, 2011 | 08:48 AM
  #195
Almatti's Avatar
Almatti
Hellcat: What proceedure did you follow to Reset the ECU? The one with the link in this Thread or Battery disconnect, etc....If you disconnect the battery, don't you lose all the settings, Navi, Bluetooth, etc?
