Throttle Lag
Old Dec 9, 2010 | 11:33 AM
Superxer0's Avatar
Superxer0
Throttle Lag
Hello everyone! I recently bought a 2008 intiniti g37s. So far i am pleased with the car but i just can't get over the throttle lag. I wanted to ask the forum before I took it to my shop, but I was wondering if the throttle lag could be tuned out? Any advice is welcome. Thanks!
Old Dec 9, 2010 | 11:39 AM
ScottyBeGood's Avatar
ScottyBeGood
Get a grounding kit, that is usually a quick fix go to Black Betty's site.
rks's Avatar
rks
This might be due the Nissan drive-by-wire. I had this hesitation in my 02 Max 6mt.
Old Dec 9, 2010 | 11:47 AM
Legz's Avatar
Legz
Hypertech or blitz tb controller might help
Old Dec 9, 2010 | 11:52 AM
Steveo47's Avatar
Steveo47
grounding kit helped me alot. Also, try driving for like 2 days with the snow button on. when you turn it off youll think your car is a race car.
Old Dec 9, 2010 | 11:54 AM
Gyoza's Avatar
Gyoza
Cheaper than all the above:
Reset the ECU (search the site for the how-to, or just disconnect the battery), then drive it like you stole it. The computer will relearn your driving style and will probably react a little better to your input.
Don't expect any epic improvements, but it worth a try before you spend any $.
Old Dec 10, 2010 | 10:12 PM
Superxer0's Avatar
Superxer0
Thanks for all the responses. I'll look into getting a ground kit.
Old Dec 10, 2010 | 10:26 PM
Steveo47's Avatar
Steveo47
it wont totally fix it, but it will help
Old Dec 10, 2010 | 10:31 PM
pauliewalnutzz's Avatar
pauliewalnutzz
SPRINT BOOSTER PERFORMANCE ENHANCER SPRINT BOOSTER INFINITI G37 SEDAN 07+ / COUPE 08+ SPEEDWARE MOTORSPORTS Arai, Sparco, Bell, Alpinestars Race Gear Distributor
Old Dec 10, 2010 | 10:42 PM
GraphiteG37S's Avatar
GraphiteG37S
Get a tune that removes the throttle restriction: UpRev, Hypertech, etc....
Old Dec 10, 2010 | 10:58 PM
droogie's Avatar
droogie
I would recommend a tune, as a good tuner will manipulate your throttle table to remove the stock restriction. Infiniti's come this way from the factory so grandma won't spin out and hit a tree. You will also pick up power. A tune with UpRev should run you about 550 or so, and you want to find a reputable shop that has prior experience with the software and nissan motors. To maximize your gains, you might want to look into some bolt on mods like a cold air intake and catback exhaust (with or without hi flow cats) before you go in for the tune.
I personally do not have a tune yet, waiting until I finish my bolt ons first.
Old Dec 11, 2010 | 02:29 AM
smashhell's Avatar
smashhell
I'll go with the grounding kit as well.
It's a $70 buck fix, alot cheaper and easier than all those other solutions.
And if it doesn't work, than try the other methods.
Old Dec 11, 2010 | 03:48 AM
NeverBoneStock's Avatar
NeverBoneStock
A tune is going to due nothing for u. U have to buy a product that will eliminate your gas Pedal delay
Old Dec 11, 2010 | 03:49 AM
NeverBoneStock
A tune will do nOthing for u . U have to by a product that will Eliminate your gas pedal delay. Sorry at the strip club
I
Old Dec 16, 2010 | 11:18 PM
CrackHeadMonsta's Avatar
CrackHeadMonsta
I
hahahaha great
