2010 G37- Cold Engine Start up Noise
Old Mar 5, 2016 | 12:04 PM
  #46
Kris9884's Avatar
Kris9884
Hate to bump an old thread but three's no need in a new thread either.
I replaced the Y-pipe with a Tanabe and the exhaust leak that I thought was coming from the old flex piece is actually still there. It's still the same note and tone but is only VERY obvious when its cold. Once its warmed up its totally gone until higher revs. I think I have it narrowed down to either the manifold gasket or the gasket between the header and cat. Is this a common problem or am I crazy and just hearing the cold start sound??
Old Mar 5, 2016 | 12:28 PM
  #47
Epiphany's Avatar
Epiphany
See if you can get a good video for us to listen to.
Old Mar 7, 2016 | 12:40 PM
  #48
ciscoizi's Avatar
ciscoizi
Originally Posted by SilentR
Like others, I was concerned with the lumpy idle, but 2 things put me at ease: 1) the sound always smooths out at exactly the same time, and 2) if you put the car in gear right away, the noise immediately disappears and the car sounds normal. Whatever it is, the computer is controlling it. If it was an oil related issue, I would think the noise would increase when put in D or R.
+1 - this is why I never worried about it as well.
Old Nov 14, 2018 | 07:42 AM
  #49
lastpharaoh's Avatar
lastpharaoh
2012 G37 Sedan Journey
Hey, I have the same issue with my 2012 G37 Sedan, if it normalnit should be an issue.... do the new Q50s have the same issue or Q60???
Old Nov 14, 2018 | 05:15 PM
  #50
2pt238's Avatar
2pt238
Don't know about the Q cars, at some point they do have different engines. The cold start noise must be related to emissions programming from a dead cold start. I just start up and select reverse to back out and as soon as i move it into reverse the noise stops.
glassjaw047
Jan 4, 2012 12:38 PM
G37SBS
13
Mar 1, 2011 09:18 AM
t-bone1924
27
Nov 8, 2010 10:36 PM
gan78mao
Dec 16, 2008 08:30 PM
SilverBullet
Oct 3, 2008 07:20 PM
