Help Maintennance on a SC kit.
Old Sep 3, 2010 | 11:15 PM
Jakex1's Avatar
Jakex1
I started saving up for a SC kit. Hopefully get it by next year.
I know aftermarket FI kits require some maintennance. But for someone driving 8-10k miles a year, how much money realistically would i need to spend on maintaining a supercharger on the G?
i searched errwhere but i couldnt find. Thanks
Old Sep 3, 2010 | 11:29 PM
Staples's Avatar
Staples
Depends on which kit you're going with... The Stillen requires specific fluid changes for the Vortech blower every 5k miles, the GTM kits which uses fully synthetic oil only needs to be changed once every 15k miles.
Then just your traditional oil changes, but I'd recommend using a high-grade fully synthetic (Mobile 1, Motul, Redline, ect) oil.
Old Sep 3, 2010 | 11:40 PM
Jakex1's Avatar
Jakex1
i wanna go with the stillen one. just the 5k mile oil change is fine?
and i use mobil 1 or royal purple. i dont think redline is available for the g37 :/
Old Sep 4, 2010 | 04:29 AM
Weiboy718's Avatar
Weiboy718
no motor oil is made for a specific car.
there's not much you'll have to do to maintain the SC. just be sure to check the belts, coolant if it's a Stillen kit. the Vortech uses it's own SC oil which needs to be change at 2500 miles initially and every 7500 after that. change your motor oil every 3000 miles. check your air filters and make sure it's clean. that's pretty much about it.
you should consider supporting mods too! like gauges to monitor your car. good luck!
Old Sep 4, 2010 | 09:49 AM
da mayor's Avatar
da mayor
come by VinnyTenRacing... we got some hidden projects coming and you can get lots of advice from me and everyone else.
also on the Wednesday night meets there are plenty of turbo guys that have mileage on the car.
Old Sep 4, 2010 | 09:56 AM
mikelr's Avatar
mikelr
Actually the GTM kit only requires fluid changes for the SC every 50k miles..
Old Sep 4, 2010 | 01:21 PM
Jakex1's Avatar
Jakex1
i've been meaning to call you, where do you guys meet up on wednesdays? at VTR? i might not be able to make this one, since my car is at the shop right now.
BANNISTER
Dec 10, 2015 04:14 PM
dlc1988
Sep 2, 2015 09:40 AM
slotterjordan
Aug 10, 2015 12:17 AM
