Help rpm jumps down Help!
Old Jun 13, 2010 | 01:50 PM
VossenG37S's Avatar
VossenG37S
I just pulled out filters and cleaned, they where slightly dirty not entirely clean buy slightly .
Old Jun 13, 2010 | 02:18 PM
VossenG37S's Avatar
VossenG37S
Not very dusty in Miami ...
Old Jun 13, 2010 | 06:21 PM
Oh I see.
Old Jun 17, 2010 | 09:48 AM
EnfinitI's Avatar
EnfinitI
Originally Posted by DPE_G35
hey,
i just got my ark exhuast installed today, and i encountered a weird rpm promblem, it doesnt happen all the time, but it happens like 3-4 times a day,
the rpm jumps down 2 slits before 0, and it feels like the car is going to shut off, but it jumps right back up under 1, and this happens on Idle only!, when driving its fine, do you think its the exhuast causing the promblem? or do i need to clean my throttle bodies? its weird because it never did that before i installed the exhaust.
thanks for the help
That's really odd that you would have this issue. I just got an ARK exhaust installed as well and seem to have a similar issue. When I am driving and push the clutch in to coast down a hill or what not the RPM drops down quickly to around 500-600 and then quickly hops up to 1100-1200 drops down to 500-600 again and then back up to 1100-1200. It does this quite a few times before it finally settles down at around 800 rpm.
I've only got 16000 miles on my car though so would my throttle bodies be dirty at this point?
Also, why would this issue only show up after installing a new exhaust?
Old Jun 17, 2010 | 09:57 AM
Weiboy718's Avatar
Weiboy718
Weird! Can you guys be losing too much back pressure?
Old Jun 17, 2010 | 10:29 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
My car does this too and i'm at 53K miles.
Been doin' it for about 10K miles just havent taken it in to the dealer yet since I think im going to try to clean the TB's first and see if that gets rid of it.
Old Jun 17, 2010 | 12:55 PM
EnfinitI's Avatar
EnfinitI
Gamedog, let me know if cleaning the throttle bodies fixes the issue for you. I'm going to check that myself as well and if it fixes it I'll post it as well.
Old Jun 17, 2010 | 01:01 PM
VossenG37S's Avatar
VossenG37S
I'm cleaning my TB Tommorow also ...
Old Jun 17, 2010 | 10:47 PM
EnfinitI's Avatar
EnfinitI
I cleaned my TB's tonight and the problem still exists. My TB's weren't exactly very dirty when I cleaned them anyway. I took a Cipher log of the issue. Here are a few screen shots.
If you look at the chart when the accelerator pedal is not pressed down at all you can see where there are the quick peaks and valleys in the other charts. That is where the RPM goes up and down.
I can send Cipher log file .csv if somebody wants to take a closer look at the actual data.
Old Jul 6, 2010 | 08:51 PM
TomieG's Avatar
TomieG
Originally Posted by Q8y_drifter
I found the test online. It was done by a Japanese magazine.
http://mkiv.com/techarticles/filters_test/2/index.html
Check out these threads. Found them after a brief google search.
HKS filters and turbo damage - The mkiv Supra Owners Club
http://forums.evolutionm.net/dynofla...er-enough.html
Wow. I just ordered some HKS Hybrid filters for my G and after reading this i am hesitant to install them. Can people that have this on their G chime in?
Old Jul 6, 2010 | 08:55 PM
VossenG37S's Avatar
VossenG37S
I have had HKS filters for over 15.000 miles with no issues what so ever I think these guys where running high boost or something to cause damage no sure but I have not noticed any cons about the filters , they have been reused after cleaning and still good.
Old Jul 6, 2010 | 08:58 PM
TomieG's Avatar
TomieG
I see. Do you oil them after or just wash and dry?
Old Jul 7, 2010 | 12:45 AM
SM_Shadowman's Avatar
SM_Shadowman
All those reviews seem to be about the HKS super-mega-flow intake filter kits, not the super-hybrid drop-ins. Obviously they're different products, but I'm not sure how different, or whether or not the hybrid filters would have better filtration. Looks like they're made of the same non-oiled foam material.
You aren't supposed to oil the HKS filters.
Old Sep 18, 2010 | 07:17 PM
  #29
EnfinitI's Avatar
EnfinitI
Anyone been able to figure out what this issue is yet? I'm still having this irritating hopping of the RPMS whilst driving and have yet to have anyone figure it out.
I took it to the dealer and they were like "It's probably your exhaust giving the ECU "weird" readings."
P.S.
I cleaned my throttle bodies and it didn't help any.
vamarris
Dec 9, 2018 11:10 AM
redlinernyc
Feb 29, 2016 11:06 PM
Rybitron
Nov 18, 2015 03:11 PM
