NST Crank + Alternator Pulley kit
NST - The Leader In Nissan 370Z Pulley Development
So NonStopTuning had this kit for a while now. Anyone tried it yet?
Here's the info i gathered so far:
On a 350Z HR (same engine) the peak gains shown was 5whp and 6lb-ft of torque. The maximum gain was at 4000-5000rpm with 10whp and 12lb-ft of torque. 3rd party dynos prove these numbers are true and consistent. The really cool thing is, the kit consists of a 10% underdrive crank pulley and 10% overdrive alternator pulley, so the alternator should provide the same power as stock. Furthermore, they are much lighter than stock (weight differences are in the link) and the kit only costs $200 for both. the gains are also evident throughout the entire power band, and not just in high RPMs.
Here's the dyno and overview...
NST (NonStopTuning) 370Z VQ37HR Pulley Kit Review w/ Dyno Charts - Nissan 370Z Forum
Haven't tried it but if the Z guys like it usually it's pretty good. Too bad install is could be almost as much as the pulleys depending on your mechanic.
Still, seems like it might be worth it for the responsiveness you gain from lightened pulleys even if the HP/TQ numbers are less.
They're local to me. I've been considering it but was waiting for someone else to pull the trigger first and report. I like the much lighter weight and the fact that while it underdrives the crank pulley, it overdrives the alternator to compensate and maintain it's OEM speed. All while shaving 4 pounds of rotational mass. I don't like the colors though...
Cool. Self install? How difficult for you? If you had a good shop do it, how long did it take the tech and how much if you don't mind sharing the info with me? What are your thoughts positive or negative?
I'll be getting a set in the near future.
One thing to be careful of though... make sure you have a good shop install these, or if you do it yourself, make sure you know what you're doing. If the crank pulley isn't seated correctly, the vibration will ruin the crank seal. Keep your stock pulley on hand just in case! That's not meant to scare anyone off from doing this mod, but it's just a warning for something to look out for.
And whoever goes for the full kit (alternator and crank), you will need a slightly smaller sized belt... this one, specifically:
Amazon.com: Gates K070786 V-Belt: Automotive
BB, they will do custom colors... just an FYI... But they seem to believe the two colors they are offering are the two hardest (durable).
