How do we feel about the Nismo Z 350HP?
350HP/ 276lb-ft of torque, unlike the older uprev motor (I think) this doesn't loose torque for more HP....or..at least the peak torque is up.
I wonder if it takes a big hit at the bottom end?
Nissanusa claims it has a free flow exhaust and "H" pipe...but I'm sure some ecu tunning is involed.
So...kinda cool to see they can bump it up to 350HP and this isn't even with direct injection.
Yeah the Nismo Z gets some better breathing parts out of the factory, along with nissan engineers that can get the most out of it. Its not unreasonable to see the extra 18hp over the 370z base.
Simple mods like an exhaust, hfc's, have netted the 370z a decent amount of gains, as we've seen so far.
I really like the Nismo Z but I am not sure it would be worth getting rid of my G for it. I want buttons to push and stuff like that on my car. The Z is still just so plain on the inside. That actually makes a difference to me.
I knew the first repsonse was going to be a smart azzz...
LOL
I guess I'm not asking if we're dumping our G's to get Z's, I'm thinking about the possiblilty of an easy 20hp gain...which sometimes with aftermarket parts is easier said than done. Esp when dynos sometimes show dissapointing gains from 500 dollar intakes and 700 reflashes.
LOLI guess I'm not asking if we're dumping our G's to get Z's, I'm thinking about the possiblilty of an easy 20hp gain...which sometimes with aftermarket parts is easier said than done. Esp when dynos sometimes show dissapointing gains from 500 dollar intakes and 700 reflashes.
Keep in mind that they're rating the 350 hp at the flywheel, not at the wheels. So gaining 18 horses at the flywheel is definitely do-able with some breathing mods. I mean, if WE are gaining say 17 hp at the wheels off of an intake and exhaust, you add roughly 16% to compensate for drivetrain loss, you're gaining about 19.72 hp at the crank
Yeah, I might be just a little off, but you get the point
Unless you have seen a dyno, I'm willing to bet that it does lose some lower end torque for high end power. Peak torque numbers won't be related to any low end RPM losses as it will generally be located around the mid to higher RPMs.
I thought the stock intake was supposed to be left alone...that is flows fine. This gain is for coupes I would imagine but the seadan VQ37 is basically identical.
I'm not being a jerk when I say this....but are people gaining 17 or so HP at the wheels with intakes and exhausts?
I was seriously considering the Nismo 350Z ('08) when I decided to go with the G37. I *loved* the back end of that car, the wheels, the low profile and body styling... the deal breaker for me was that when you sat in the car and looked back, all you saw was a plastic wall and the rear window. I know the G37 doesn't have much of a back seat, but it's enough to cram a couple females back there!
I gained +16 to +19 at the wheels with just an intake.
__________________
Fujita has since come out with newer short ram intakes that seem to flow a lot better then their first setup a year ago.
Injen's CAI, there's a review thread on it.
__________________
__________________
