15k, 22k schedule maintenance necessary?
Old Jan 22, 2009 | 02:07 PM
Degenerazn's Avatar
Degenerazn
Do I really need these? I've had my car for about 15 months, 18k miles on it and all I've been doing is going in for oil changes. These maintenance around about 400 bucks a pop and I would rather not spend that money if all they're gonna do is check stuff and rotate my tires. My car is bought, not leased and I don't plan on selling it.
Old Jan 22, 2009 | 02:08 PM
shumby's Avatar
shumby
get it done
Old Jan 22, 2009 | 02:20 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
The only way to rotate the tires on an 'S' is to dismount them. So maybe it's worth $400.
Old Jan 22, 2009 | 09:22 PM
w0ady's Avatar
w0ady
dont waste your $. oil changes and free inspections are all you need. change your tranny and differential fluid when they recommend and thats about it.
Old Jan 22, 2009 | 09:54 PM
tristan1334's Avatar
tristan1334
+1 on that. At 15k your car is still brand new.
Old Jan 28, 2009 | 11:58 PM
junyea's Avatar
junyea
If these services are not required, for performance issues, then y are they suggested by the manufacturer?
Is it for the $?
Old Jan 29, 2009 | 12:25 PM
Graham's Avatar
Graham
There is no rotating tires on an S, the wheels are different size front to back. You might check your air filters, after 18k mine looked pretty dirty, and I'm in Socal LA area, not in the middle of a desert with sand storms and such.
Old Jan 29, 2009 | 12:32 PM
Ducati's Avatar
Ducati
Do the service! In my experience once you skip a service you will always wonder if you made a mistake. Also, in todays environment, you don't want to give ANYONE a reason to cancel a warranty. Legally they may not be able to do so, but they will call your bluff and see how much money you want to spend to prove them wrong. The cost of which may be more than the repairs they are denying because of a missed service...
Do it, you will never regret it. Dont do it and you may regret it.
My 2 cents...
Old Feb 2, 2009 | 02:29 PM
Thrillhouse's Avatar
Thrillhouse
Infiniti can't cancel your warranty because you didn't have them do your 15k service. As long as you've done your fluid changes on time they have to honor the warranty.
If I remember correctly the only extra stuff at 15k is air filters. Everything else is pretty much just visual inspections.
Old Feb 2, 2009 | 02:57 PM
sahiwal007's Avatar
sahiwal007
i was planning to get the 15k service too, dont know if its important, i would want my G to be in top shape.
Old Feb 2, 2009 | 09:38 PM
w0ady's Avatar
w0ady
Is it for the $?
yes service dept is where they make a lot of their $. example: $13 air filter at autozone costs $60 at the dealer.
My 2 cents...
recommended and required are 2 different things.
infiniti should do a free multi-point inspection when they change your oil. if anything is wrong, they will point it out then. only things i ever did on my g35 5at was a full transmission flush and differential fluid changeout around 50k miles.
stealth210
General Tech Questions
27
Jul 26, 2017 06:48 PM
ill12will8
Oct 26, 2015 10:09 PM
Mr Infinit
Oct 16, 2015 09:43 AM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Victory
Sep 28, 2015 10:49 PM
