ecu reset?
Old Jan 8, 2009 | 11:41 AM
ironhurts's Avatar
ironhurts
ecu reset?
i just finished installing HKS exhaust and Berk HFC's to go along with the Stillen Gen III CAI, so i wanted to reset the ecu. i disconnected the negative battery terminal overnight.
when i started the car this morning the radio presets were unchanged...does this mean that the reset did not work?
Old Jan 8, 2009 | 11:42 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
correct...
Old Jan 8, 2009 | 11:49 AM
ironhurts's Avatar
ironhurts
what am i doing wrong?
Old Jan 8, 2009 | 12:18 PM
MaxToTheG37
dunno... never heard of that... i know when i installed my grounding kit the time i had mine off it reset all my stations... so I
Old Jan 8, 2009 | 12:35 PM
Callaway's Avatar
Callaway
Arm flailing tube man
try this method.
https://www.myg37.com/forums/faq-and...isconnect.html
Old Jan 9, 2009 | 12:16 AM
ironhurts's Avatar
ironhurts
has anybody reset their ecu by disconnecting the battery? if so, how'd you do it???
Old Jan 9, 2009 | 01:15 AM
aliiin's Avatar
aliiin
BMW Defector
are you sure you are disconnecting the negative terminal of the battery and not allowing it to touch the battery for at least 15 minutes? your predicament seems really odd...
Old Jan 9, 2009 | 02:47 AM
Arrowhead's Avatar
Arrowhead
Your case is really weird...are you sure what you disconnect is a negative battery cable? Maybe you can try the other way without disconnecting the battery. It's easy and all about timing. Once you get it, you can reset ECU anytime you want without erasing all your presets.
vamarris
Dec 9, 2018 11:10 AM
delfinparis
Oct 8, 2015 06:06 PM
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
harlemcat45
Sep 9, 2015 09:35 AM
