DS/MM Disabled
Old Dec 12, 2008 | 05:51 PM
DiamondGCoupe's Avatar
DiamondGCoupe
DS/MM Disabled
This has happend to me 3 days in a row now, every time I drive, MM/DS do not function, the only thing I seem to be able to do is use my paddle shifters but it will switch back to D after a few seconds. Only a few times throughout 3 years did this happen in my G35 and would immediately work after a restart but now it is 99% of the time disabled. I did notice today once that the NO KEY light flashed just before but the key is in the same place it always is. I tried driving with the spare key, same problem..
I always drive in MM and an ECU reset solved nothing, I did clean my car the other day with some whipes but I've done this 100% of the time and never experienced this before. Anyone else?
Old Dec 12, 2008 | 06:11 PM
finagle69's Avatar
finagle69
wow, that's pretty odd, man.
I'd say you've earned a trip to the service department.
Old Dec 12, 2008 | 06:27 PM
Mike's Avatar
Mike
^^ I agree.
Warranty time
Old Dec 12, 2008 | 06:29 PM
shumby's Avatar
shumby
sounds like the sensor is not picking up that you slapped the stick over in DS and it is behaving like it is still in drive and you use the paddle shifters.
Old Dec 12, 2008 | 08:29 PM
DiamondGCoupe
Just ran some errands 4/5 times I got in my car it didn't work and on the way home it finally did. I also noticed that when in D mode nothing lights up, guess something came lose down there.
shumby's Avatar
shumby
ya sounds like it for sure
Old Dec 12, 2008 | 10:41 PM
gomezg37's Avatar
gomezg37
That happened to my car. Just take it in and they will fix it.. They said it was some piece that they had to replace..
Old Apr 8, 2009 | 12:07 AM
gmlee86's Avatar
gmlee86
Hmm.. time to bump an old thread. Anyways, I've been experiencing this too for the past couple months while away at school. I can get it into MM no problem, but the computer will stick it back in D without touching anything. ECU resets do nothing and a lot of the times, it'll switch back to D on the display a few seconds after being in MM and will just stay there, even when moving the shifter from D to DS and then on MM + or - until I turn off the car and then it'll work again in MM for another 5 seconds and do the same thing after restarting. Any ideas on how to fix this before taking it to the dealer when I go home for summer break?
I doubt any mods are causing this because everything has been on the car since last June and running fine when the problem just started happening in late January/early February.
Old Apr 9, 2009 | 04:29 PM
gmlee86's Avatar
gmlee86
Bump.. anyone?
Old Apr 9, 2009 | 04:41 PM
finagle69's Avatar
finagle69
mine did this yesterday!! i've even been able to hold the gearshifter up in the "upshift" position and have it lock into Drive. have to turn the car off then back on. I've got an open ticket with the dealership to see if they can find out what's wrong.
Old Apr 9, 2009 | 04:52 PM
Achilles's Avatar
Achilles
PM Diamondcoupe........... Might know what's up, probably a service issue...
Old Apr 9, 2009 | 05:35 PM
DiamondGCoupe
I still haven't taken my car in to get this fixed. When I first start the car DS will work just fine until I put the shifter in D or N, then the Key light will flash on the display and I can only use the paddles until I restart my car. Good to know other people had this problem, I made an appointment for next Wednesday so I hope they can get this fixed.
Old Apr 16, 2009 | 03:44 PM
DiamondGCoupe
I just had my car serviced, they replaced the shifter, problem solved. Also had the full exhaust replaced because of an emissions sensor malfunction.
Old Apr 16, 2009 | 04:18 PM
finagle69's Avatar
finagle69
^Thats good info. My car will now not stay in DS/MM for more than a few seconds. But it will only go into it once per start. Meaning, turn car on, switch to DS/MM, car goes back to D for the entirety of the trip. Turn off, then back on, and can repeat the process.
Old Apr 16, 2009 | 04:26 PM
elite's Avatar
elite
It took you 5 months to get this taken care of?
Amaadkhan2k
Oct 4, 2024 01:20 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
lobuzz311
Sep 15, 2015 10:09 AM
OBG37
Aug 27, 2015 03:56 PM
